Question about Lanzar Car Audio & Video
Protection mode? lanzer vibe 230 will not stay out of protection mode popped a couple of fuses and now i've re done all the wiring. it's all good and i get the power i should but very quiet sound . if the amp and stereo are turned down then it will work just fine but as you start to turn anything up the power fluxuates on the power light and going up farther it clicks in to protect mode everytime any advise?
  • Lanzar Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check your connections. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection mode? - protection-mode-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Posted on Dec 19, 2014
    Problem Solver:
  • 8 Answers
What guage of wire are you using to power the amp? Should be 6 guage or larger. Do you have a good ground to the frame of the car (metal inside trunk area)
Is the amp new or used?
Also your speakers could be shorted inside. Use an ohm meter to check them. They should be about 4 ohms useually. Test them UNHOOKED from the system.
Try different spakers. If you cant solve the problem, the amp might be damaged.
Posted on May 27, 2008
It is stuck in protect and wont come out
bro...i had problem like that before and i found out that the load(speakers) was high thats why the fuse always blow...or...check the wire to the speakers if they are sorted or touched.gud luck
Oct 26, 2012 | Rockford Fosgate T1000-1bd - 1000W...
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 19, 2011 | Harman Kardon Audio Players & Recorders
Speakers made popping sound and now receiver is in protection mode
It sounds like you have some wires that are touching cause the reciever to protect itself. Go over and check all wiring and make sure you have nothing touching. Unplug device while you are doing this and then when done plug back up and see if that fixed issue.
Jan 31, 2011 | Denon AVR-1801 Receiver
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Soundstorm amp
do you have a model #?
The MAX PRO is the only one rated @ that power.
Let me know, and Ill look it up!
Jan 08, 2009 | Lanzar Vibe 218 Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
My A3201Q
Try unhooking the power, ground, and remote wires for a couple of minutes, also check all fuses on amplifier and fuse for power cable (usually under hood around battery), and don't forget to check ground wire connection for "good" contact.
Mar 15, 2008 | Car Audio & Video
Lanzer vibe 416 1000watt Amp stay in protection mode completey
I'm no pro but I've fixed a few amps in my time.When you had the 12's hooked up it was working fine you say,but when you upgraded to 15's is when the problems started. You probably bridged it too low of ohms and it maxed the amp out,it got too hot and started to burn up the channels. all that matters when you buy speakers and amps. The 12's was probaly 4 ohm coil speakes and the kickers are 2 ohm. The kickers bridged together positive to positive, negative to negative would bring it down to 1 ohm load witch I dought the lanzar can handle. If your a fix it yourself kind of person like me. I can point you in the right direction on where to looke for parts to fix your amp....
Jan 30, 2008 | Car Audio & Video
My amp wont go past protect mode
Disconnect all speaker wires and signal cables from the amp. If it powers up (no protect light), the wiring needs to be checked. If it still shuts down (goes into protect), the amp likely has blown output transistors.
Dec 01, 2006 | Lanzar Vibe 218 Car Audio Amplifier
Car Audio & Video Logo
390 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
