Question about Panasonic NN-S740BA Microwave Oven
Panasonic Microwave Model # NN-S740BAW 7. AUG 2000 BUILD. Makes a funny, rattling sort of hum then shuts off after about 4 - 6 seconds. It was working fine last night, but nothing doing this morning. Worth fixing? I've packed this beast all over the country for the past decade. Not exactly emotionally invested, but hate to abandon it after all that history.
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: panasonic microwave oven model nn-p994sf
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 22, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 23, 2009
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Shuts off after 4 seconds and plate does not turn
The problem is most likely caused by 1 or 2 bad door switces often the result of food partical build up, the latches will need to be replaced.
Mar 13, 2012 | Panasonic NN-H275 Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Light stays on continuously in Panasonic microwave oven.
Problem solved by adjusted the door to close correctly.
Oct 21, 2009 | Panasonic Microwave Ovens
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
You can find an authorized Panasonic servicer here.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-S740BA Microwave Oven Logo
395 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
