Question about KitchenAid Washing Machines
Top loading kit aid tub off center - KitchenAid Washing Machines
  • KitchenAid Master
  • 8,220 Answers
This video shows how to completely dissemble a machine similar to yours.
Posted on Sep 30, 2010
I have awtw6700tw1 with the noise when spin cycle will the bearing fit it .
If you are getting a noise like a jet taking off during the spin cycle you will need to replace the tub bearing. The bearing only comes with the tub assembly kit. It also includes the seals. Here is the tub kit to order.
Nov 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My machine gets out of balance when in the spin cycle no mater what size of load or what type of clothing being washed. Model # A308 Ser# 870406GP. I have taken the front off and determined that the...
Hi and welcome to FixYa, I am Kelly.
Nice to see there are some A series washer still in service. Ok here goes on the what can cause this problem list.
1. The iiner wash tub.
a. Some one with small fingers needs to feel in between the outer tub cover and and the inner wash tub for missing chunks of the top of the wash tub ring. It is filled with concrete FYI. If the tub corroded and it tossed a bit of the top balance ring you will always have an off balance condition in the spin cycle.
b. Also grab the top of the inner wash tub and attempt to teeter just the inner wash tub. If it teeters there is a problem under the inner wash tub. This can be because of the mounting stem
item 24 of this link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789&diagram_id=28323416#d28323416 or the tub bearing Item 18 of the same link.
If the tub bearing is bad the outer wash tub can move indepently of the inner wash tub. The should move as one. Grab the agitator and press on 3 sides of the outer wash tub with opposing force and check for excessive moment. (FYI the mounting stem and tub bearing repairs ar not for the novice repair person.)
2. The CORK damper pads on the top of the machine base are worn. Item 22 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789 Pushing the outer wahs tub off center and against the cabinet should result in the outer wash tub retring to near center (within 2 inches as viewed from the top) If it does not return to near center there is a problem with the damper pads.
_________________________________________________________________________________
Here are my thoughts on your washer and what to consider. If your unit is in fair material condition and you do not have lots and LOTS of rust on the base I would repair it. Honestly this machine will outlast you if you have it "re-furbished" Refurbishment would be
A. New Tub Bearing
B. Mounting Stem
C. O-ring replaced on agitator shaft inside the transmission lower housing PN 2-10286
(^ ^ ^ ^ -- Must purchase transmission grease.
(there is the possibility that the Transmission drive gear would need replaced PN 2-10315)
D. Damper Pad Kit.
E. Motor mount spring and roller kit PN 2-5000
F. Both belts Items 18 and 19 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789&diagram_id=28323416#d28323416
G: Water injector kit.. No part number but still available.
I know this is probably a lot more information that you wanted but.. the bottom line is you own one of the "Cadillacs of Maytag." As long as the macine base and cabinet are in fair shape you can keep it in service with parts that are always available.
To fix your current problem it will show up when performing steps 1 and 2 at the top of the post. The unit will most likely have to have the inner and outer tubs removed to correct the problem and it involves about 2 hours of labor. You may have to find a very experienced repair person to have your unit re-furbished IF and I reiterate IF it ever comes to that.
Thanks for choosing FixYa,
Kelly
Feb 24, 2011 | Maytag Washing Machines
Large amount of water leaking from bottom
lift the top first by 2 clip between top and front panel at 2 inch from each side with a metal plate,after removed the front panel 2 screw on the top, and just see where the machine leaking
possibility drain hose,pump,hose pump to tub,seal kit at the center top of the transmission.
good luck
hypersteve
Dec 15, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
Water leaks from the machine tub while it is in the wash cycle or turned off with water in the tub. I can empty the tub using the spin cycle without any leaking
you have bad tub seals. is there stains on the walls inside the washer and the water is leaking in the middle bottom of the tub?if the washer is old get a new washer,did one last week but the washer was in good condition it was close to 300 bucks.you have to pull the agitator,remove the top ring,with a spanning tool you need to remove the center parts and pull the inner and outer tubs and the three nuts and bolts holding the outside tub on and replace the two pieces in the middle it's a bearing and a seal kit,but you need the tools to do it,like i said if the washer is old replace it or call someone in to do the job for you
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
Tub won't spin the water out. and how do you take off the knob that has wash rinse spin
pully bearing kit under neath may need to replace . center comes out unclip knob
Feb 05, 2010 | Maytag PAV2300 Top Load Washer
Leak underneath tub
check for a broken seal at center of tub , if so , write down the brand & model and go to an APPLIANCE PARTS SHOP, and get a new RUBBER SEAL KIT, hope this helps , AJ
May 20, 2009 | Washing Machines
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
I have a Kitchen Aid clothes washer and the tub that you put clothes in won't stay centered. When it spins during the spin cycle, it gets out of balance and thump, thump, thumps............me and the...
there are 3 springs that hold it to the frame,remove the 2 screws from the washer head,one on each side,now pull up on the head and lift the front out and up,you will see 2 spring clips pop them out with a flat screw driver,open the lid and pull the washer case toward you,sit it aside and look at the other springs they will tell you where the other one goes,also the tub sits on a triangle bracket make sure that is in place to,under the tub,let me know-mike
Sep 26, 2008 | Washing Machines
Leaking water from bottom of tub
this is bad it needs a center seal/bearing kit this is qite common in the Amana / Maytag line.they are kinda hard to install you may need a service tech to do this for you the kit runs around 80.00 dollars and has instructions. if you need more help you can email me at familyappliancerepair@yahoo.com
Dec 06, 2007 | Amana ALW480DA Top Load Washer
Washing Machines Logo
19 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
