Question about HP Pavilion dv6000z Notebook
MY HP COMPUTER WILL NOT STAY ON...WHEN TURNED ON IT SURGE OFF AND ON...WHAT CAN I DO...
Desensamble
Posted on Oct 01, 2010
L E D christmas lights stay on when shut off.
No it's not. Your LED Christmas lights are okay. Your surge protector is fine too although the switch on your protector is an SPST type - it is connected to one line of your AC outlet. When turned off, the line with the switch is physically cut, but the other line is still alive. Some LED circuits and TFL lights blink even when the switch is turned off, probably because one line of the AC power is still (a)live. If this worries you, just unplug the LED lights from the protector.
Nov 23, 2013 | Garden
Dell dimention E310 green light will go on and off
You turned off the surge protection....Ummm did you remove the plug from the wall after doing this?. If you did then it has become corrupted due to a bad shutdown meaning that the system had not fully shutdown when power was turned off which has corrupted the data stored on the MBR ( Master Boot Record ) but I do not understand why you can not restore from a previous good known configuration. If you have a recovery disk or windows os boot disk try to repair it, if it will stay on long enough that is.
If you turned off the surge protection and did not remove the plug from the wall because you turned off the surge protection it is not available to protect your devices etc and in turn a lightening strike close enough will fry the computer due to EMP ( Electro Magnetic Pulse )
You may need to have a qualified person look at it but if it has been fried due to EMP sorry to say but you can say goodbye to the computer as it will not be repairable, You may be able to reuse the case as long as you use another Dell motherboard as Dell have an unusual way of mounting the M/B ( Motherboard ). I hope this helps.
Oct 18, 2012 | Dell Dimension™ E310 PC Desktop
Hpscanjet 2400 is not powering on,what maybe the problem?
• Ensure that the power cable is securely connected between the
scanner and a live electrical outlet or surge protector.
• If the power cable is connected to a surge protector, ensure that
the surge protector is plugged into an outlet and turned on.
• Disconnect the power cable from the scanner and turn off the
computer. After 30 seconds, reconnect the power cable to the
scanner and then turn on the computer, in that order.
Jul 07, 2011 | HP ScanJet 2400 Flatbed Scanner
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Screen wont stay on when power button is pushed
Get a surge protector.
More than likely a surge caused it.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 11, 2010 | HP 2009M Monitor
Tower won't turn on
Brandi,
Please check the following:
1. Make sure the the surge protector is securely plugged into the wall. Test this by plugging in a light / lamp to it, to make sure it's working.
2. Make sure that the surge protector is turned on.
3. Check to make sure that the power cable from the computer to the power surge protector is securely plugged in.
4. Check to see if the computer will power on now.
5. If this still isn't working, remove the power strip/surge protector and connect the computer directly to the wall.
6. If this STILL isn't working, try plugging your computer into a different outlet in the house to see if the outlet in your home might be bad.
6. If your computer STILL isn't powering on then I'm afraid the worse has happened, which is one of the following issues:
1. Bad power supply (they are cheap, around $20-40)
2. Bad motherboard (they are sort of pricey, around $50-200)
3. Bad CMOS battery (they are cheap, around $5-10)
I can fix all of the above and order parts for all of the above, if you are in need of parts.
I hope this troubleshooting guide helps you! If this resolves your issues, please mark this question as resolved and select my answer. This will assure customers that I can help them with their issues.
Thank you,
Larry Braziel
May 12, 2009 | HP Computers & Internet
Computer power won't turn on
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Jul 20, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
