Question about Maytag MTB2156GES Top Freezer Refrigerator
Model Maytag MTB2156DE: Was in storage for 1 year. hooked up now and icemaker does not make ice. Freezer does not seem to be as cold as it should be. Not sure if I have a problem with the solonoid at the back that meters water into the icemaker or the refrigerator has lost coolant in storage or ?
    President:
  • 1,218 Answers
Good day,
Check the freezer temperature. If it is much above 10 degrees then the ice maker will lock out. That is by design.
If it is too warm freezer temperature, check to see if you can hear the fan running in the freezer compartment. If it checks O.K. the go to the bottom rear of the machine and see if the condenser cooling fan is running. Both have a tendency to freeze up after extended off periods. Sometimes, just flicking the blade will get them going. If not, the faulty one must be replaced.
If everything is running and has been for 24 hours or more, then yes, a lose of refrigerant is possible, and you will need the services of a trained service tech.
I would ignore the ice maker problem, until the freezer temperature issue is resolved, since if the machine is over 5 years of age, the factory warranty has expired leaving you with a pricey problem.
Posted on Sep 30, 2010
Ice in icemaker, but it is not dumping cubes. Water supply seems to be ok, arm is in down position & very little ice in box, so that should not be stopping it.
check your freezer temp with a freezer thermometer the freezer should be close to zero degrees, if you are not cold enough the icemaker may make ice very slow. possibly clean the coils underneath or in the back of unit. if that all checks ok check water pressure , if you have a filter it may need to be replaced
May 12, 2011 | Maytag Refrigerators
Icemaker wont make ice. Any ideas?
tempt in freezer not cold enough or water inlet is frozen . defrost it with a turkey baster and hot water .. this may be caused by the water valve not closing complety and if so replace the water valve .. mm
Aug 03, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not hooked up (on purpose). The ice
Sounds like you are not going to use the automatic icemaker, so I would remove the whole icemaker unit which will include disconnecting the wire harness behind the icemaker which will shut off power to the icemaker and will also give you more storage room in your freezer compartment.This will not harm the refrigerator or the icemaker, you could also disconnect the waterline if you want.Please note that this solution applies to the top freezer,and bottom freezer style refrigerators only thatt DO NOT have dispensers through the door. Good luck !
Dec 02, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Freezer is almost always running....
If you look at the icemaker, you will see a metal wire which runs along the side of the unit. If you manually swing the wire arm up until it locks in place (about 90 degree swing from the normal straight down position) you will have turned the icemaker off. (Alternatively you can unplug the electrical plug from the icemaker which goes into the freezer wall.)
If the icemaker is not turned off, it will periodically cycle, which turns on the ice cube mode release heater during it's cycle, putting unnecessary heat into your freezer. You do not need to plug the ice maker supply line. This should be a Fix-Ya for your refrig.
Feb 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Jun 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
Maytag MTB2156GES Top Freezer Refrigerator Logo
158 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
