Question about Vacuums
Hi I have purchased a Black & Decker Hidden-Bottle Water Cooler with bottom loading. As soon as I opened the box, it smelled really strong. I original thought is was just the sent of new. It has seen been 3 weeks and it still smells and water also tastes the same. I haven't cleaned it before usage (as it was indicated to have been sterilized and it was wrapped in plastic. I accidentally threw out the owners manual. I tried running almost all of the 18 litres of water through machine (hot and Cold) to remove the smell, but water still tastes the same. What can I do? Thanks
  • 490 Answers
Immediately return the product and don't drink from it in the meantime. There should be no taste or smell.
Posted on Sep 30, 2010
WHERE CAN I GET A user manual for a Black & decker ORA 32.4 vacuum please
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Black & Decker model by clicking the link below.
https://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90616683,BDH3600SV.pdf?_ga=2.47809504.690377823.1513544467-1337893124.1494963821
You can purchase a wide variety of high quality Black & Decker replacement parts for your Black & Decker vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Black%20%26%20Decker
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 17, 2016 | Black & Decker Vacuums
How do I troubleshoot noise from black & decker FHV1200 flex
Hi Thomas
This is Tabitha with Black + Decker Customer Service. We would be happy to troubleshoot the noise you hear from your FHV1200 Flex Vacuum. Please email us at wecare@sbdinc.com and reference case # 04271192 We would be happy to assist you further with the issue you are having.
Jan 30, 2015 | Black & Decker Black Decker FHV1200...
My 2000W hepa Black and Decker Vacuum cleaner
the power head might be binding or possibly the belt slipping
Sep 17, 2013 | Black & Decker Vacuums
I purchased Shredder Model BD-S600 on 5/6/11. This was to replace another Black & Decker Shredder that I had for only a few months also. Today, when i attempted to turn shredder on to shred some...
If it's like my BD-S600 your motor is already burned out!! Same thing happened to me with this shredder after 3 months of minimal home use. I had to call them and pay $13 to send shredder back to them to have a new one sent to me, and I have already been on the phone with customer service due to problems with the new one after 5 minutes of use! Good luck to you; I know I will NEVER purchase a Black and Decker shredder again! My last shredder (a Brother) lasted 8 years with no problems and I really miss it!!
Jul 05, 2011 | Black & Decker Vacuums
Bissell 9200-T ProHeat 2X will not spray I have gone through the priming process it will work for a few seconds and quit. I have had it open and checked a few tubes but not sure what to do next. This...
ARE THE TANKS SEATED PROPERLY AND THE AUTO-LOAD GASKETS
IN PLACE?
Check the bottom of the Water Tank and the Formula Bottle to make
sure each has a red (or black) auto-load gasket attached and facing outwards
and that the ventilation tube is not submerged as it allows air in so the solution
can flow.
May 28, 2011 | Bissell 9200 Upright Vacuum
I have the bissell littlegreen proheat pet, and every time we turn it on to use it smells REALLY bad.. we always clean out the dirty tank and clean what we can get to but it STILL smells! i need to know...
Don't have a solution to the whole odor problem. But my machine smells musty or moldy so I have taken the dirty solution tank and turned it upside down and shook it filled with detergent. You can see the white pipe, or that's what I call it open so additional water drains out. But a bigger problem with my machine occured about 3 weeks ago. I was using my machine and when I picked it up off the carpet there was a black liquid that had come from the bottom of the machine. Which is not good given I have white carpet. I contacted the Bissell Company and they had me send the machine to them and they provided a prepaid shipping label. Also the company send me a bottle of pet and stain remover to get the stain out. As of yet the stain has not been totally removed. A bit of advice so this doesn't happen to you is to put a towel under the machine when using. I say this because I'm not sure if it is connected to the bad smell and thinking it might be a black moldy liquid. Hope this helps.
Mar 26, 2011 | Bissell 1425 Little Green ProHeat Handheld...
Purchased ProHeat 7920 Po-Tech recon. Unable to use main brush as no water/cleanfluid. Belt drive is ok. Grateful advise location of fluid jets as not visable behind main brush. Turbo brush works well.
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Nov 16, 2010 | Vacuums
How do you clean grout in between tiles in the bathroom
Strong clorox and water solution.. spray on and let soak for half a day then rinse off...
heatman101
Aug 27, 2010 | Black & Decker S500 ScumBuster Handheld...
Need filter for Black & Decker Floorbuster
Hi there - just found two packages of 2 filters each (SVF1) while cleaning out the closet, and searched for someone online who needs them - instead of posting on eBay and waiting. Are you still interested?
Jan 08, 2010 | Black & Decker Vacuums
Black & decker parquet 1800w hepa h13 need
I'm not sure what bag your referring to. The only bag for this is the carrying bag. So I have to assume you mean one of the filters.
There are three filters for this vacuum.
  • Primary Filter.
  • Exhaust Filter.
  • Secondary Filter Element.
I have included a link to a site that carries the replacement parts and a diagram of the vacuum.
Hope this helps.
On another note If it doesn't help I really don't feel to bad because I'm in Detroit Michigan. And I'd rather have a dozen useless vacuums hanging out in New Zealand any day. :)
Find me a job there and I'll buy you a new vacuum. :)
http://www.ereplacementparts.com/black-and-decker-hv6000-type-opp-corded-hand-vacuum-parts-c-4167_8887_10329.html
Oct 17, 2009 | Black & Decker HV6000 Bagged Handheld...
Vacuums Logo
198 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
