Question about Dymo LabelWriter Thermal Printer
On a home network, my Dymo Labelwriter twin turbo will not respond to a print command from the computer to which it is attached, but will print just fine from a remote computer. Both computers are Apple products running the latest Snow Leopard. Both have version 8.2.0.978 software. But the remote computer has driver version 2.1.5.0 installed, while the local computer has driver version 2.1.7.0 installed.
  • 2 more comments
  • gwsmithgw Oct 01, 2010
    On the local computer, the print command is totally unresponsive- either via button push or via menu. The print utility does not activate, either. No error messages, also.
    I have not tried uninstalling and reinstalling the Dymo software on the local computer because I don't know how to uninstall completely all of the Dymo software. Some more background- this problem popped up only after I did a clean reinstall of Snow leopard on the local computer for some unrelated purpose. The previous Dymo installation had worked fine. The problem on the local computer happened after I reinstalled the Dymo software after the Snow Leopard clean install.
    Can you guide me on how to do a clean uninstall of the Dymo software and driver? Then I will try to reinstall the Dymo software again.
  • gwsmithgw Oct 02, 2010
    Tim, I am a long time Mac user and pretty knowledgeable. I just cannot believe with printer software that all you have to do is trash the application to get a clean uninstall. There must be drivers installed somewhere, as well as various preference files. How do I get rid of every last piece of Dymo software installed elsewhere?
  • gwsmithgw Oct 03, 2010
    I got it to work after simply trashing the app and reinstalling. But I think the problem actually was something else unrelated to the install. I have a Magic Trackpad instead of a mouse. After the reinstall, I still could not print with a tap on the trackpad, so I tried a push on the trackpad and then it printed. Then, after that time, it would print OK with just a tap on the trackpad. Sort of a weird situation, but thanks again.
    Wayne
    Thanks for the help.
    President:
  • 2,777 Answers
Very interesting, I wouldn't think the disparity in driver versions would matter, however have you tried uninstalling the printer completely / removing all software from the local machine and trying to reinstall it?
Does it do anything at all when you try to print locally? Do you get any errors when you try to do it? Such as communication errors, anything like that?
Thanks
Tim
Posted on Sep 30, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 02, 2010
    Sorry it took so long to get back to you, was out and about for a bit. I am going to write a response right now on how to do this.
    Just wanted to keep you posted.
    Tim
  • Tim Grayson
    Ok it is extremely easy to do a "clean" uninstall on a mac :). Something tells me you maybe were a windows user before and are used to the way that uninstalls things which is far from clean. All you need to do is bring up your Finder window (if you don't know how to do this let me know, it should be just a button on your button bar...) and go to the APPLICATIONS folder. In the applications folder locate the Dymo software (it may be a folder itself or just the program). All you need to do is drag anything that references DYMO to the Trash Can on your computer. You can also just CTRL+CLICK on the Dymo software and select Move To Trash, it's as simple as that.
    Next you will want to get the latest and greatest Dymo software for Mac, I've found it for you, you just download it by click this:
    That will start the download right away, and should put it right on your desktop. It may even open itself when it's done. If it does not, just open the file downloaded, it should be right on your desktop. Inside you will have the new Dymo program. Just drag it into the applications folder, and go through any steps it may pop up for you. Simple as that, and it should work!
    Thanks
    Tim
  • Tim Grayson
    The driver is integrated into the kernel, if you have advanced linux knowledge you can take it out of the kernel and recompile it... but it really isn't necessary.I assure you. It is really pretty impossible for the driver to mess up on a mac system... the preferences file... that is a bit trickier but can be done. I would try just reinstalling the dymo app first as described, but if you still have problems just delete it again, do the following steps I'll give you here, then reinstall the app.
    On the desktop, click File, click New Folder, type Print Prefs, and then press RETURN.
    On the Go menu, click Home.
    Double-click Library, and then double-click Preferences.
    Hold down the Apple key, and then click each com.apple.print.*.plist file. For example, hold down the Apple key, click com.apple.print.PrintCenter.plist, and then click com.apple.print.PrintingPrefs.plist. In this example, the com.apple.print.PrintCenter.plist and com.apple.print.PrintingPrefs.plist files should be highlighted.
    Drag the files that you highlighted in step 4 to the Print Prefs folder that you created in step 1.
    On the Apple menu, click Restart, and then click Restart.
    That way if the preferences file is not auto-generated as it should be, you can replace it with the files you moved..
    Tim
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Is this dymo twin turbo labelwriter enabled to connect wirelessly
You can network the labelwriter using the Dymo Network Print Server device, but this is not wireless.
It is possible to connect using 3rd party print servers, but this can be pretty hit and miss. It's possible you would find a 3rd party wireless print server that would work with a labelwriter, but you may have a problem with the twin model - the dymo print server recognises that there are (effetively) 2 printers in one machine, where-as a many 3rd party servers do not.
So it's possible you could find a wireless server for it but it may not allow you to use both rolls...
Aug 21, 2012 | Dymo LabelWriter Thermal Printer
My Dymo Labelwriter Twin Turbo will not print from stamps.com, nor will it print regular mailing labels
Kathy,
Stamps.com supports this thermal printer. If you would like assistance, can you please email me at social(at)stamps.com?
Thanks!
Chuck
Stamps.com
Sep 27, 2010 | Dymo LabelWriter Thermal Printer
OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
Dymo Twin Turbo install on network
You need to download the Dymo software 7.8 from Dymo. Start with the system that has the printer plugged into it. Install the software and make sure it works (prints labels) Now go to Printers and Faxes and find your printer. Right click and choose properties. Then the Sharing tab. Choose a share name that is simple. The printer will now be know to other installs as \\computername\sharename
Go to the next computer and install the software - CHOOSE NETWORK when you get the part about connection. Either enter your host computer info from above or BROWSE to it via Windows Networking. All should be fine now.
Dec 08, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Not printing
I have installed the Dymo LabelWriter Twin Turbo and it iwll not print my labels. Any suggestions?
Aug 15, 2008 | Dymo LetraTAG Thermal Label Printer
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
Dymo LabelWriter Thermal Printer Logo
341 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
