Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Why did my steam cleaner stoped makeing steam
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Oct 29, 2010
Does this cleaner heat up the water for steam? It is called a steam cleaner, but I do not see anything about how to regulate the temperature of the water to make the steam and so no one gets burned.
Steam is steam is steam - it has a temperature of 212 degrees F and if you go any lower it is no longer steam - condenses back to water. Capiche? If you pressurize the steam you can then raise its temperature to a super heated condition. How do you think a pressure cooker works??????
Aug 26, 2017 | Vacuums
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
How do i get ceramic tiles to have a shine again. they are not high gloss but they used to have a shine to them
You might try a steam cleaner like the Shark Steam Cleaner. If you use a polish, sometimes that makes it worse and makes your tile dull. Just use plain old soap and water. The Shark also scrubs your floors as it cleans.
Feb 13, 2015 | Vacuums
Shark portable steam cleaner heats up but does not produce steam
Built in thermostat...sounds like you need to buy a new steamer.
Dec 12, 2013 | Vacuums
Have shark steam cleaner. Brown sticky smelly water started coming out after using 5 or 6 times. Nothing has been added to water.
add some white vinegar in the water let it boil them empty and repeat about 3 times , when you finished using it always make sure you empty it..
Aug 17, 2013 | Euro-Pro Ultra Steam SharkTM II Hard...
I can't take lid off steam cleaner!
need more information like make and model of steam cleaner
Jan 14, 2013 | Vacuums
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    Stoped heating the water, in my Ultra steam shark 2.
    there is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
    open the machine and replace it with the same value. it is written on it.
    Jul 29, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
    The steam dose not come out any more
    heatman101
    rrt
    Jan 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
    Euro-Pro Shark hand held steam cleaner model #sc618hd
    Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
    May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
    Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
    385 people viewed this question
    Top Euro-Pro Vacuums Experts
    Dennis Key
    Dennis Key
    Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
