My PC wont start up, all it does is beep constantly. I don't have any idea what to do. Please can you help?
    Problem Solver:
  • 7 Answers
Beeping when the computer first starts up indicates a hardware failure. It can be bad memory, bad motherboard or something else is bad.
You can look up the beep codes from your computer manufacturer's website under support or Google It.
If you are not able to replace memory or motherboard on your computer, You will need to have a computer tech look at your computer.
Posted on Sep 30, 2010
F&p E331T constant beep
The ActiveSmart system that manages the fridge will beep when there is fault, and the amount of beeps will indicate the fault code.
To understand the fault code, a technician would also need to know the version of activesmart, and the product ID on the grey label on the bottom right of the fridge.
Dec 02, 2016 | Refrigerators
I have a quanta 3082 MB in a HP Pavilion zd8230us laptop when I startup it beeps constantly got any ideas? anyone
The beeps with have a pattern to them. Listen closely when you first turn the laptop on and listen for the pattern. It might be something like 1-3-2 (1 beep, wait, 3 beeps in a row, wait, 2 beeps) It will repeat for listen for a bit to make sure you have the correct pattern. Once you have that pattern got to the HP webpage, in the support section, in the search type in "beep code errors". It will give you a list of beep patterns and tell you what the problem is. It could be the RAM, it could be another problem with the motherboard; those codes are what you need to have first.
Dec 24, 2014 | HP Computers & Internet
Horn wont stop beeping
not sure this will help but i once had a ford that had a short in the stering colum start there first
Dec 18, 2012 | 2001 Fiat Stilo 1.6
How to remove beep sound after the system sound?
the beeps ate called post
Then what happens does it restart ? or just wont boot up ?
A bit more information please.
Not sure what you mean by 'when the hard drive beeps
does the hard drive start when you turn the laptop on
(at which point a do the beeps occur a single beep isn't unusual) and it stops when you turn the hard drive off - a beep then would be unusual.
I suspect you don't mean that, & if the laptop is working fine otherwise then I wouldn't worry about it or do you mean something else completely?
make sure the ram modules have secure seatings also check all power and data leads attached from motherboard to hard drive the same will apply for your graphics card
hope this helps
Oct 10, 2012 | Computers & Internet
Constant beeps
if there is beeps on it then its probably your ram has come loose or your cpu fan try to find installing RAM on PC on youtube there should be a video there and do the same for cpu fan ....hope this helps if you like you can google your pc's manafacturer error beeps like if its 2 short then one long it will let you know exactly is in error....bonnell
Apr 22, 2012 | Gigabyte Ga-g31m-s2l Motherboard Intel G31...
I have a sony vaio VGC desk top - it is probably 6 years old or so. I went to start it th other day and it sounds like its firing up and you can hear the fan working - then a constant beep noise starts...
The constant beep signifies that one or more RAM has(ve) been dislocated from the RAM socket(s). Try to re-assemble the RAM(s) into the proper position(s) and re-start your computer. I hope this will work the best for you.
Dec 29, 2010 | Sony VAIO® VGC-RC310G PC Desktop
The pc wont boot up and just gives a constant beep and does not stop. What does a constant beep mean?
First you should check which BIOS are you using. This will help in narrowing the diagnosis.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
Recommendation:
Troubleshoot the system memory.
Troubleshoot the video card.
Troubleshoot the motherboard.
May 23, 2010 | Everex GA3400 PC Desktop
My acer is 2 months old and constantly beeps, and freezes any idea on how to fix this?
Hi, if it beeps at the start when you start the laptop and it does not start the load the windows, then it is the issue with the RAM you need to get it replaced. If it beeps between normal window the it might be possible that there is problem with the Battery. As you said it is only 2 month old it should be under warrenty get it checked.
Feb 25, 2010 | Acer Aspire One PC Notebook
PC will not start
This sounds like a memory error, can you define the beeps. There is a thing called a "beep code" on all motherboards, the website for the motherboard defines what the beeps mean. For example: one long beep followed by two short beeps of continous spaced beeps without a break. chris http://www.motherboardsrus.net
Jun 06, 2009 | Dell Precision Workstation 670 PC Desktop
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
