Question about Kenmore Refrigerators
Hello, I have a Kenmore Elite 106.54606300 and it stops making ice. I don't know what is wrong with it. I bought it from brand new and after two years later, it stops producing ice. Anyone knows the problem? Thanks
  • 78 Answers
SOURCE: kenmore elite ice maker stopped making ice,
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope thiswould help you
Have a good day : )
Posted on Sep 05, 2011
  • 1294 Answers
SOURCE: Kenmore elite washer problem
Click on kenmore (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, u hv your manual on line.
Posted on Feb 12, 2008
  • 1122 Answers
SOURCE: ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Posted on Sep 21, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
  • 1122 Answers
SOURCE: Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Posted on Dec 16, 2008
My ice maker on my Kenmore Elite has stop making ice. The water still works, but it no longer will make ice. What can be wrong with it, and how can I fix it?
If the water flow works, I would check the wire that controls the water flow to the icemaker. It shuts off the water when the tray is full and fills the ice maker when it senses that more ice is needed. It typically is over the ice tray. This can be dislodged and reseating it will solve the problem.
Let me know if this doesn't solve the problem. Thanks.
Jan 31, 2011 | Kenmore Refrigerators
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My ice maker isnt making ice. i think i need a new filter. could that cause this.
Hello, my Kenmore was also not making ice about 2 years ago, but everything else worked. It seemed that the tube directly inside the freezer where it was filling the ice trays was frozen. My husband used a hair dryer to unthaw the tube. It's been working every since. Also, my sister had a Kenmore Elite, with the same problem but her husband didn't know what the cause. So they also tried the hair dryer, and now it works fine.
Thanks
May 19, 2010 | Kenmore Refrigerators
Kenmore Elite side by side wont distribute ice
you may try dumping the ice and rinseing the bucket make sure door switch is closed.
Oct 16, 2009 | Refrigerators
Kenmore Elite Bottom Refer Internal leak
Hi, look and make sure the inlet tube to the icemaker is inside the fill cup. Make sure there is no ice build up in the fill tube also.
I hope this helps some, please let me know if I can help further.
Thanks Vic
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
