Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley Davidson 883 2004
My 2004 Harley Sportster 883 has been sitting for a year, replaced battery, but it won't even turn over
  • cor Jul 10, 2008
    Sounds like the issue I have as well. Bike has a fully charged battery, lights, horn etc work fine. When turn ignition, just hear a click sound.
    I looked at the plugs are both are sparking correctly when turn ignition. When I removed the plugs but attached the cap, the engine turns over (no ignition obviously).
    Seems strange the engine will crank when the plugs are out but not when they are inserted..
  • Steven Honeyfield
    Steven Honeyfield Dec 26, 2017
    i have the exact same problem with my 87 883 not turning over with plugs in take them out turns over no worries it has a brand new battery cant seem to work it out
I have a 1980's somthing 883 with a fucked up hand built wiring harness and for some strange reason when I hit the starter it just clicks. So I moved the relays and got shocked. Whats my problem???
Posted on Jul 31, 2008
    Problem Solver:
  • 4 Answers
Had that problem with sportster,wrong starter, not enough power
Posted on Apr 12, 2013
Rear brake caliber slides and caliber wont open and shut sometimes i have rear brakes then i dont
Posted on Jun 21, 2011
I have a 1980 sportser the bike starts and runs.When i turn it off after a few minutes of riding it wont even turn over till it sits for a few hours?The light works just here a clicking sound.
Posted on Jun 29, 2008
    Problem Solver:
  • 9 Answers
Do the lights or anything even come on? Probably starter/solenoid contacts needs to be cleaned or somthing from it sitting. Could even be the starter relay. If everything else seems to work on the bike then its probably something with the starter system.
Posted on Jun 11, 2008
My 2006 harley davidson xl883c sportster backfires through the carb when i slow down or turn
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below:
Good luck
Harley Davidson Sportster error codes and how to access them
Aug 23, 2012 | 2006 Harley Davidson XL 883C Sportster...
My 1998 Harley sportster won't start but the speedometer get's power
Different fuse. Check the fuse block located just behind your battery. Just pull the cover off and slide out the main fuse block, the very bottom one is blown if the starter wont turn over.
Jun 10, 2012 | 2000 Harley Davidson XL 1200 C Sportster...
I just bought a 2000 harley davidson sportster it has been sitting for 5 years it fires right up but will not rev up it will die. How do i fix this?
You need to remove and completely disassemble the carb. It sounds like the main jet is stopped up or the slide is not operating as it should. If it's been sitting for that long, a carb overhaul is probably what it needs.
Good Luck
Jul 14, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
1972 sportster that the clutch lurches forward bad eneough that i can hardly get it in gear it is fairly new but has been sitting for about 5 years
I would check it for dry crack from sitting, These parts can still rust and oxodize and go bad, Even uif they are new
Jun 11, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Won't start?
With just this info.Not knowing if the engine is stock or has bigger cams or high comp pistons.I would say check the starter solenoid by running jumper wire from one side to the other.then check ALL connections for corrosion and tightness
Jan 24, 2009 | 2004 Harley Davidson XL 883 Sportster
Lands Phones Logo
499 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
