Question about Samson Airline 77 Aerobics Wireless Headset System FREQUENCY / 801.375 Microphone
There is a piece inside the mic that is not working. when i turn it on half the time, it is just extremely loud fuzzy feedback.
    Prodigy:
    An expert who has answered 500 questions.
  • Samson Expert
  • 611 Answers
Call Samson. They can help you troubleshoot.
Posted on Feb 14, 2011
Microphone not working
I'm sure it works. Just wear headphones so that you don't get loud feedback from the mic hearing the speakers. Then make sure if there are any physical switches that they are on. Click volume icon click mixer find your mic and uncheck mute
Dec 01, 2013 | Toshiba Satellite L455D-S5976 Notebook
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
The internal laptop microphone above the screen is producing feedback from the speakers and everytime the volume is raised above half way the feedback starts (very loud). It's definatley the mic because...
Most likely there's a shortage with the microphone connection, or is gone. You can turn if off if you dont use it via the control panel. But if you use microphone quite often then you can buy an external mic off ebay or some place you like. They come in elegant designs as well and they are fairly cheap.
Hope this helps.
May 03, 2011 | Toshiba Computers & Internet
Hi im using the carlsbro gd 4000 in a 3 piece rock and roll band we are using an oldmike shure c606 and we cant get any volume out of the mike and its distorting the vocals we dont know whether the p.a.s...
Proper placement of mics versus the speakers of a PAS is important to avoid feedback. Your speakers need to be toward the audience from where the mic is. If the mic can "hear" the speakers you will likely have feedback. The mic should work even though it is a consumer grade mic.
WORD OF CAUTION: There are a LOT of fake SM58 microphones being sold... even on Ebay... SOME are fairly high quality and others are not.
Mar 31, 2011 | Music
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
Poor voice connection on yahoo im
Some times it might be problem with Network jam.
You have to check Your mic..
>Go to Action
>Call Setup
>Next
There you will find an idication tab to view your Signal Quality of Mic...
TRY to speak...There wil you find The differences...
And follow the instruction and Finish..
>Check your Jack of MIC(same time your Ear speaker Jack too)
>Change your Mic
Still same
>Tell the other one to change his mic......
Sometimes other Electronic device may create noise(Speaker and so)
Your problems Should be solved...
Mar 23, 2010 | Yahoo Messenger
I had a cordless mic hiiked to my system and there seemed to be an overload of feed back evertime i got close to the sub. the feedback then got so loud that the sub stopped working
You need to reduce the level of the microphone so that is not so loud. Feedback can be controlled by equalizer adjustments and speaker positioning. Did the sub get blown out?
Aug 08, 2009 | ElectroVoice SxA180 Subwoofer
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Connex 4300
Check for proper shielding,ground, turn mic gain down, move mike farther away from radio, turn off other accessories nearby-ie.-am/fm radio
Apr 02, 2008 | Connex 4400 320-Channels Base CB Radio
206 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
