Question about Gateway BCM94306MP Network Adapter
I cant connect to the internet the problem is my pc no find any network adapter
    Sergeant:
  • 231 Answers
What you will want to do is open your Device Manager To do that you must go to start/control panel/and if you are using using windows xp switch to classic view and go to System/Device Manager/and under network adapters hit the plus sign right click on the device and uninstall restart your computer and it will say New Hardware Found. This link will give you the driver you need to install hope this helped http://support.dell.com/support/down...&fileid=152055
Posted on Sep 30, 2010
Cant connect to lan modem
1. check first your lan connections,
click start, go to control panel, click network connections din check your local area connection.
2. right click the local area connection, then try to disable and enable it.
3. if not been solved,
try to look the driver of your ethernet drivers
look at and search your motherboard's brand and model then search it and download for your drivers for your network adapter.
or you may try this,
1. right click my computer
2. click properties
3. clcik hardware tab
4. click device manager,
5. click network adapter
6. right click the name of your network adapter then, click update
Jan 26, 2010 | Gateway 500GR PC Desktop
Cant connect to internet verizon says network
Have you installed tnhe drivers for your Network Adapter? Without the drivers the adapter is, as far as the computer knows, not there. Did you get a disk with your computer and/or adapter? If so install the drivers and problem should be solved.
Dec 20, 2009 | Dell Ethernet Card Network Adapter
Connected to wireless network, but cant browse internet.
I think there might be lost in the packet sending.
You said the PC is still connected to the network but not able to go online.
Is there any other wireless computer which is able to go online wirelessly and working fine.
If yes then try to uninstall and reinstall the adapter.
If not then check the router wireless settings.
Click Here for more info about networking.
Oct 08, 2009 | Computers & Internet
I cant connect using my linksys wireless adapter...it was working fine before but when i downloaded LELA in my wired pc, the adapter stopped working thus, my 2nd pc is not connecting to the internet..
  • hard wire the laptop to the router, which reestablishes the connection.
  • set the connection to be wireless
  • follow the prompts and you will soon be wireless again
Sep 13, 2009 | Linksys WUSB300N Wireless Adapter
Internet not connecting
Update the drivers for the network adapters. You may also run recovery cd if you have for those computers.
Sep 09, 2009 | Microsoft Windows XP Professional SP2 for...
My computer cant connect to the internet after i installed windows 7
try instlling a different browser like mozilla firefox and opera or google chrome and check
Apr 22, 2009 | SMC PCI-X Quad Ethernet Controller (p/n...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Computers & Internet Logo
167 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
