Question about Sharp Microwave Ovens
Microwave works but not oven Sharp R958/(SL)M
MicrowaveSvc
  • 9047 Answers
SOURCE: User's Manual of Sharp Microwave Oven Model R-9H56
Found this posted under Whirlpool instead of Sharp, but I'll be happy to answer it here.
While that one may not be available, we have one that may be close enough to work:
http://www.microwavedisplay.com/r9h66_r9h76_r9h84b_r9h94b_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
najah
  • 180 Answers
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
Posted on May 30, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
Posted on Sep 28, 2009
  • 8909 Answers
SOURCE: I have a SHARP MICROWAVE
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 06, 2010
The keypad on my sharp microwave model R-953 (SL) M is not working. Anything I press on the keypad does not respond, but the light comes up whenever I open the door. It works well till 2days ago.
it could be any number of things . usually taking it into a repair shop and having it checked is only way to know for sure and get estimated repair cost .Mine was the door switch and cost 50.00 for them to repair .
Sep 20, 2015 | Sharp Microwave Ovens
SHARP MODEL R895(SL)M TURNTABLE NOT TURNING
Check turn table motor operating voltage on the motor if the voltage is normal then check motor pulley(crack or broken) ,if o.k replace motor with the same type,if the voltage is missing go to the control panel and find out any wiring problem,if everything o.k replace control panel.
Jan 15, 2011 | Sharp R-303CW Convection / Microwave Oven
I have a SHARP MICROWAVE oven SL - R-950B / R-954B. The Start button has stopped working recently and so the oven needs repair. Please send mt the address and phone number of the SHARP SERVICE CENTER in...
I hope this helps.
Dec 06, 2010 | Sharp Microwave Ovens
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
SHARP R 383(SL) M
Hi - You can download the manual from the link underlined in blue below:
R-383
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 30, 2008 | Sharp R-383 900 Watts Microwave Oven
I've got a sharp R-754(sl)m microwave and the lcd display is unreadable,is this easy/cheap to repair or do i need a new microwave?
I do this repair for US customers, but since you're in the UK, I would recommend you contact Quality Electronic Repairs.
Jun 18, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
