Question about VeriFone PINPad 1000SE Network Terminal
How do I fix err no mkey on pin pad1000se - VeriFone PINPad 1000SE Network Terminal
Getting mkey error on pinpad 1000
IT MEAN I THINK THAT YOU LOOSE THE DEPLOYMENT KEY INJECTKEY INJECT&APPL LOAD NEED TO BE INJECT AGAIN
Dec 01, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
My canon xt rebel says err cf and wont do anything i bought a new one an the same thing whats wrong
One of more of the CF pins inside your camera are bent over. This is very common. The solution is to remove the main circuit and replace the bent/broken pins. Most repair shops will charge between $150-$200 to fix this.
Wes
Sep 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Hi - We have an error code on a Canon Model 2800 : E000001-0002 Any ideas on how to fix the problem? Thanks! Paul
E001
0000 The main thermistor detects 250°C or higher.
0001 The main thermistor or the sub thermistor detects overheating (hardware
circuit detection).
0002 The sub thermistor detects about 295°C or higher.
Main cause The fixing film unit is faulty (i.e., the thermistor has a short circuit). The
main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To clear the error, execute the following in service move:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Fixing film unit
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 ?
(short circuit)?
YES: The thermistor has a short circuit. Replace the fixing film unit.
REF.
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
2. Main power supply PCB, DC controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
BUT FIRST: under service mode *28* copier, function, clear , err turn off and on maybe it will work.If it works check that you have good air flow around the copier.
Apr 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Regency scanner r1070 error message fr err, will not scan
i have same problem with my scanner what my prob was is moisture got into the radio and it sat for while and corosion ate one of the pins of a crystal causing it to have fr err on any channel i put it on replacing the crystal fixed it for me but with scanners anything could be wrong
Jul 18, 2009 | Radio Communications
Nissan stereo sy702 with constant err flashing after flat battery
WRONG! Leave the radio on for 1 hour using the key and accessories to reset then enter the pin. You get the pin from nissan customer service in your area but you need to supply your vin/chassis number.
To enter the pin you press buttons 1-4 corresponding to the number of the pin eg. pin is 1023, press button 1 once, 2 ten times, 3 two times, 4 three times
Jan 03, 2009 | 1992 Nissan Pickup
Display panel shows "Err"
it sounds like maybe the pins in the back of the memory car port may have gotten damaged when you did not get it in straight, I don't know of anyplace in your area to have the camera serviced, but I think it will be a costly repair.
Dec 13, 2008 | Fuji FinePix S3 Pro Digital Camera
CF Card Err
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins?
You maybe able to fix it with pincers and a needle just align the pin or pins that are out of place, i did this and it worked for me and now my camera is working fine. and for free.
Good luck
Mattias
Oct 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos digital camera, display err 2 in window. will not take any photos. The battery is fully charged and istalled correctly.
ERR 02 usually indicates a problem with reading the memory card. Remove and reinsert the memory card (check the pins in the camera with a strong light to make sure no pins are bent). If that doesn't work, try another memory card. If it still doesn't work, the camera may need to be serviced.
Jul 24, 2008 | Canon Cameras
Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Jan 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
VeriFone PINPad 1000SE Network Terminal Logo
214 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
