Question about DeVilbiss Pressure Washer Hose 25' 38" Id Rubber Has
Need part that regulates the engine speed on Devilbiss pressure washer
    Scholar:
  • 100 Answers
If you are talking about the idle down assembly on the devilbuss pressure washer they are no long available
Posted on Nov 01, 2010
Motor runs but no water pumps through
It's possible that the 'unloader' in the pump is plugged. A local small engine repair shop can replace it (generally under 50 bucks). Of coarse you have the hose hooked up to it and the water on.
Mar 19, 2013 | Devilbliss DeVILBISS Devap DVH2600...
ENGINE RUNS FINE WHILE HOLDING THE WAND TRIGGER BUT , WHEN I RELEASE THE TRIGGER THE ENGINE STALLS OUT
you have a faulty presure relief valve. it is building up presure and killing the engine.
Jun 16, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Does my Honda 5.0 EXH2425 take mixed gas?
No it is a 4 cycle engine and does not use mixed gasoline.
Jun 01, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Have a honda 5.0 hp engine on a pressure washer model belive is a de 1504 not sure of make, starts if you use starting fluid but then dies, getting gas to the bowl at botttom of carb but not to carburator
Hi there mburns44 i believe your problem is either that either the Air/Fuel mixture is too rich and causing it to flood or you have clogged jets. carburators are tricky and often times need to be cleaned or adjusted by a professional. I hope that this helps :)
Mar 30, 2011 | Devilbliss DeVILBISS Devap DVH2600...
I have a Devilbiss air compressor DF430-2. It builds pressure past the pressure relief 120 PSI. What could be the issue? is the pressure switch adjustable?
Yes it is adjustable. however if the diaphragm is defective it won't work. You can adjust it counterclockwise to lower pressure switch. Unplug the compressor first then back off three turns at a time. then check the switch. If you remove the gray cover off of the regulator it will have the directions on how to adjust it on the inside cover.
Jan 28, 2010 | DeVilbiss Air Tools & Compressors
What kind of oil do i use in pump for devilbiss exwgc3240-1 pressure whasher
Dear jim_5,
Most domestic pressure washers use normal multi-grade engine oil. 15/50 wil be good. Industrial and high pressure washers usualy use gear oil (90 sae).
Regards,
fulltech.
Apr 11, 2009 | Honda Garden
DeVilbiss Pressure Washer Hose 25' 38" Id Rubber Has Logo
122 people viewed this question
Top DeVilbiss Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a DeVilbiss Garden Expert? Answer questions, earn points and help others
