Question about Health & Beauty
I have a FreeRider Kensington-s mobility scooter. When traveling on flat ground i hear a soft skweek and a low rumbling sound. This sound isn't there when going up or down hill only on the flat. At first I thought it might be wheel bearings but these seem to be OK. Could this be a problem with the gear box? In the 5 years I have had the scooter I know that the grees in the gear box is OK. I had a thought that the sound MIGHT be from the motor ? Could it need new brushes. I don't travel more that 5 miles a week in it so I think it must be a gear box problem. Thanks Lionel
gewiz
  • 1263 Answers
SOURCE: freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Posted on Oct 01, 2009
SOURCE: PARTS FOR A FREERIDER SCOOTER
a grouling noise from the differencal howls when going full speed
Posted on Nov 23, 2009
  • 61 Answers
SOURCE: i have power in to the control panel but no output
The Dynamic DS100 is not a sealed unit but is usually a replacement part. Unfortunately there are very few people in the UK that actually repair them. If you would like to open up the box to have a look at it yourself, the procedure is as follows:
Remove the 4 visable screws from the bottom of the box
Remove the smaller of the blue rectangular stickers from the bottom of the box
Remove the screw that was hidden by the sticker
Remove the 4 screws from the front of the box (where the plugs fit in) and pull away blue plastic part
Lift off the bottom metal cover
Remove the 3 screws that hold the lower PCB in place
Gently lift the lower PCB upwards to reveal the upper PCB
Remove the 3 screws from the middle of the upper PCB
Lift upper PCB out to access the top of the board
Hope this has been of some help to you.
Good Luck!
Posted on Apr 07, 2010
mcdevito75
  • 1970 Answers
SOURCE: Missing manual
mcdevito75 here, Hello Dianne, you can check online at your chairs name then .com or contact any surgical supply outlet they should be able to contact your chairs company for a new manual.
Posted on Jul 02, 2010
  • 5 Answers
SOURCE: need a manual for a freerider kensington S
most scooters are equiped with a seat that can be turned through ninety degrees so that it i eaier to get on and off the scooter if this is the cae for the scooter you have and own then turn the scooter seat ninety degrees so that the seat is side on to the base then grab a hold of the base of the seat and lift you sould find the scooter seat is easily removeable and can be then replaced in the same manner in some cases you have to hold down the lever that enables the seat to be turned to do this and lift the seat at the same time once you have turned it through the ninety degrees this is the case for almost all mobility scooters now however there are a few exceptions failing this then read te manual you should of got with your scooter when you purchased it however you may not have one if you purchased the scooter second hand but if this is the case you can usually find the appropriate soloution by entering the name and make and model of your particular scooter into a web search engine you may have to visit several web sites before you find the manual you are seeking but most of them are out there in cyberspace somewhere good luck and best wishes I hope your scooter brings you many hours of joy and freedom
Posted on Oct 01, 2010
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
Battery loses charge when going up hill. Also hear clicking noise, but don't see anthing hitting the wheels. Is there a local authorized repair dealer near Williamsburg, VA, that could do a...
Hi, Something maybe touching the battery terminal and arcing is occuring. Check terminals again.
You may have to strap down the battery better. Good luck
Aug 12, 2011 | Pride Go-Go Elite Traveller Plus HD...
I have kingston s freerider mobility scooter and the battery meter kees going from green to red and slowly back up to green can you help? thank you
Hi
It Sounds like you need new Brushes for the Motor as you are getting Intermitting Energy Readings .
Gerry.
Aug 10, 2010 | Health & Beauty
Missing manual Do you know where I can get a manual for Freerider Kensington mobility scooter thanks Dianne
I need a manual and wiring diagram for a electric mobility mobility electric power scooter wheelchair model chauffeur 230
Jul 01, 2010 | Electric Mobility Mobility Electric Power...
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Freerider mayfair, no life at all in scooter
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
Jul 24, 2009 | Health & Beauty
Does the Freerider kensington have oil in the drive motor? if so how do I check it and what type and quanity does is it use? Also does anyone have a workshop manual for this
No Oil but you do have a grease nibble located on top of the gearbox, get hold of a grease gun and give it three squits of grease.
Regards
GeWiz.
Mar 15, 2009 | Health & Beauty
Health & Beauty Logo
74 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
