Question about Garmin GPS
Customer Question...Customer owns Garmin Nuvi 1200 model GPS and has it fully charged and connected to the car charger and when she turns it on it will go back off, and also wont upload maps??? We have bad weather in our area is this causing the map loading??? And what could b the issue with the unit not staying on??? Please help customer is traveling and needs this help asap!!! Thank you, Sears Employee
    Scholar:
  • 38 Answers
This sounds like it is set to turn off automatically on loss of external power (the normal setting) and ther is something that is interrupting the power connection (intermittant external power) which causes the unit to keep turning itself off.
Check to make sure there is a good connection where the power cord plugs into the "cigarette lighter" or power port. If you have a 2nd power port on the vehicle, try changing the connector to the other port and see if that changes the behavior or fixes the problem.
If that does not do it, the next most likely cause is a broken wire in the power cable that intermittantly makes and breaks contact. If that's the problem, a new power connector cable will fix it.
It is very unlikely the weather has anything to do with it.
If that doesn't do it, contact Garmin for their free technical support:
http://www.garmin.com (and press the Support button)
or 1-800-800-1020
It could be other things but the Tech Support folks will be happy to help.
Posted on Sep 30, 2010
I dont know how to charge my GARMIN nuvi 1200 with the usb cable
There are 3 ways to charge your garmin nuvi 1200 as follows;
  1. Connect your satnav to a computer with the mini USB cable. Plug the narrow end into the satnav, where the power cable goes, and the other end into the USB port of your computer. Both computer and satnav must be turned on. It will take about 8 hours to charge like this.
  2. Connect your satnav to your car charger and plug the charger into the cigarette lighter socket of your car. It will take about 4 hours to charge.
  3. You can get an optional mains charger which also takes 4 hours to charge the satnav.
May 23, 2011 | GPS
Tip
Garmin Nuvi 1200 Manual Download
Download Garmin Nuvi 1200 Manual
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Have you lost your Owner's Manual for your Garmin Nuvi 1200 GPS?
Would you like a digital copy of the Garmin Nuvi 1200 Users Guide for easy searching of terms and quick reference?
The Nuvi 1200 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Garmin Nuvi 1200 QuickStart Download
Garmin Nuvi 1200 Webupdate
Garmin Nuvi 1200 Favorites Backup
Garmin Nuvi 1200 Hard Reset
on May 14, 2010 | GPS
Tip
Garmin Nuvi 1200 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1200 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
I have a garmin nuvi 200. I'm having problems trying to charge the device. I have tried charging it in my car as well as the computer. Once I try charging it a black screen appears that says garmin as...
This is meant to happen when it's connected to your computer but not to your car charger. Sometimes it happens, when connected to a car charger, because the mini USB plug on the charger lead doesn't go in far enough into the satnav. It feels like it's fully in but it's not. If you push it in further it should solve the problem.
It takes 8 hours approx to charge a satnav connected to your computer but only 4 hours approx with the car charger or mains charger.
Apr 22, 2011 | Garmin nuvi 200W GPS Receiver
How do I recharge my garmin 1450
There are 3 ways to charge a garmin nuvi satnav.
  1. You can connect it to the cigarette lighter socket of a car with the charger lead that came with it. This method takes about 4 hours to fully charge it.
  2. You can charge it with a mains charger which has to be bought seperately at shops that sell garmin satnavs. This also takes about 4 hours to charge.
  3. You can connect it to the USB port of your computer with a mini USB lead. Turn on the computer and the satnav. This method takes about 8 hours to charge fully.
Feb 07, 2011 | Garmin nuvi 200W GPS Receiver
Tip
I hope that helps.
on May 14, 2010 | Garmin nuvi 1200 Car GPS Receiver
Tip
Download Garmin Nuvi 1200 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1200 GPS?
Would you like a digital copy of the Garmin Nuvi 1200 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1200 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
How to charge battery
There are 3 ways to charge the battery in your garmin nuvi satnav.
  1. Connect it to a computer with the mini USB lead that should have come with it or can be bought in any computer shop. This is the slowest method taking approx 8 hours.
  2. Connect it to your car cigarette lighter with the charger lead which should have come with it. This takes approx 4 hours to charge fully.
  3. Charge with a mains charger. This does not usually come with a satnav but can be bought seperately in shops that sell garmin satnavs. This method also takes approx 4 hours to charge fully.
Dec 29, 2010 | Garmin nuvi 255W GPS Receiver
Hello. I have a Garmin Nuvi level 200. The car charger was damaged so I have purchased two at two separate stores. Neither works. When you plug it into the car charger, an icon showing "garmin connected...
The problem is not the power lead. It's the socket on the back of the satnav. Due to wear when you plug in the mini usb plug it feels as if it's fully in but it's not. Push it in further and it'll work ok.
Aug 11, 2010 | Garmin nuvi 1200 Car GPS Receiver
Tip
Garmin Nuvi 1200 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
GPS Logo
135 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
