Question about Samsung P30 Notebook
My laptop is not running on battery ? - Samsung P30 Notebook
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 30, 2010
How to Save my Laptop Battery?
Charge battery fully (with laptop off) then unplug AC power. Do not continuously have power plugged in. This will ruin your battery. Remove battery when not in use for long periods. To refresh battery charge fully then run laptop till it turns off. Turn on again and wait for it to turn off. When laptop wont turn on, charge battery fully again and repeat process about 3 times. This should extend an old battery's run time.
Oct 18, 2016 | Computers & Internet
Battery will only charge for a few seconds
try running laptop without battery (usually removed by sliding tab on bottom of latop to release battery) if laptop runs fine then probably faulty or dead battery.............replace battery. If laptop does not run, turns off then probably faulty adapter........replace adapter.
Dec 16, 2013 | Gateway NV51B15U AMD E350 Processor 156...
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
My battery charges but the laptop wont run on the battery
If your power adapter appears to be charging your laptop battery, but the laptop will not run on the battery or only runs for a short time this usually indicates that the battery will not hold a charge and needs to be replaced. Although it should run fine with the power adapter connected.
Jan 26, 2010 | Dell Inspiron 1521 Notebook
Charging it doesnt want to charge the battery and wont run off ac power . the battery is bad but it still wont run on ac power
Laptops must have a good battery in order to operate. If you take a good laptop, and remove the battery but leave it plugged in to AC it will not run.. Go out and get a new battery and you should be fine.
Aug 11, 2009 | Computers & Internet
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
Laptop does not run on battery
does your battery have some of those little circles underneath, that when you press one, it shows battery charge?
Oct 14, 2008 | Toshiba Satellite M115-S1061 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Samsung P30 Notebook Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
