Question about Hisense LCD1504 15 in. Television
I am having trouble scanning channels for set up to antena box
  • 476 Answers
Hi, this model does not have a digital tuner so you need to do is either connect the antenna box to the antenna in connector in he rear of the TV and set the TV channel to Ch 3 or 4 depending on what your choice is, and the other is to use the video and audio out RCA jacks in the rear of the antenna box and connect to either one of the auxilary connectors located in the rear of the TV(vid1,vid2 etc.)
Posted on Sep 30, 2010
DOES THE SHARP T V MODEL lc46sb54u HAVE ADIGTAL TURNER, IF SO HOW DO YOU ACTIVATE THE TURNER
it has a digital tuner that also does analog channels. You dont need to active it. I fyou are trying to get the channels over an antena, go into the menu and do a auto scan for channels. Set the auto scan as "cable". If you are trying to get cable channels over 19 it wont work without a box. The digital channels are scrambled for cable.
Sep 09, 2011 | Sharp LC46SB54U 46 in. LCD TV
Good Afternoon, I have no cable where i live now, but i have a analog converter box, how do i install it to my tv to get local channels?
you install the cable wire into the box or antena into the box then the cable or rca cables into the tv. set the tv input to the right input (usually channel 2 or 3 for a cable) or input one for the rca cables then you need to hit the scan option on your converter box to scan for the channels and the tv to scan for the channels. please let me know if this works
Mar 14, 2011 | Televison & Video
Do i need to buy a converter box for this tv
No,this tv is a digital tv,just reqiure a good antena like a digital antena or a roof antena.Hook it up.Just go into tv menu setup and set up to pick up AIR not CABLE and enter to scan for DTV free air channels.
Feb 01, 2011 | RCA L26WD26D 26 in. LCD TV
How change setting to received a digital signal. Look like TV is in Analog mode. I put a coverted BOX and see TV without any problem but without converted Box, I see a white screen with noise. TV Model:...
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
Jan 24, 2011 | Protron PLTV-32 Television
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
May 05, 2010 | Emerson EWC1304 13 in. TV/VCR Combo
I have analog tv, combo dvd vcr and magnavox converter how can i conect them
Put ur tv in channel 3.Take the colax cable came with the converter box put it in the hole in the converter box said tv in the hole cocnverter box,the other end of the colax cable put it in the tv set hole said antena.Now take ur anatena signal an indoor or roof antena put it in the converter box hole said antena in the converter box.Turn on ur converter box power on go to menu use scan channels,u should ready to go, when the scan channels is finish.
Oct 21, 2009 | Televison & Video
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
May 01, 2009 | Funai Trutech 13" TV
Hisense LCD1504 15 in. Television Logo
590 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
