Question about Kalorik STP23783 Iron with Auto Shutoff
I am getting a warning and e1 error code???? - Kalorik STP23783 Iron with Auto Shutoff
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
How do I know when my IR4500SC iron has enough water as it is filled sitting flat?
Fill then stand it up to view the fill level. Unless you see a warning I doubt you can overfill it. Just top off the tank and go.
Nov 10, 2014 | Irons
Gravity feed steam iron
If you have been using tap water in your iron, and your water has lime or calcium in it, then the iron is probably clogged up. You might try using a product like "Lime Away". Read the warnings on the bottle first. Don't get it on your skin or in your eyes. Don't breathe the mist or steam. The bottle I looked at also had warnings about how it would mess up some counter tops or sinks.But if the iron doesn't work anyway, carefully pour some into your iron maybe about one fourth full, then carefully shake the iron to get the stuff all over the insides of the iron holding the iron like you would if you were ironing. Let the iron sit for a bit, then shake it again, maybe a couple more times like that. pour it out into an old bowl that it wont ruin, and see if there are a lot of minerals in the liquid. If there are, that may have cleaned it enough to start working again. Pour enough water in the iron until it is half full, plug it in and turn the temperature up to where it will produce steam, but don't iron any clothes yet because there is still cleaner in the iron. turn the iron so it is like you are ironing, but don't let it touch anything. Hold it over something like some old rags. If steam comes out, don't breathe it, but let it come out for a little while. Pour out that water and refill with fresh water and let it steam over the rags again. Pour that water out and all the chemicals should be flushed out of the iron. Carefully wipe the hot plate off to get any chemicals off the plate. Good Luck
Nov 02, 2013 | Irons
Bosch gas range error code F11
Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it.
If the F11 is still there most likely it's the control panel.
God bless you
Feb 01, 2013 | Bosch Evolution 500 HGS5053UC 30"...
Why does the engine light start flashing when i brak
stop immediately, call AAA for a tow to your mechanic.
Generally a flashing "Check Engine" light requires immediate attention to avoid possibly very expensive engine damage.
If you have a friend like me locally who has a OBD Engine analyzer, you get the error codes, translate the code for free and fix it yourself if you have the skills. I got my Innova Brand at WalMart for $120 in Hawaii. Mechanics will charge $100 to hook up the analyzer, plus $60/hr minimum service fee.
Nov 17, 2012 | Bosch Audi A4 1.8l Engine Motor Turbo 02...
Error code on ion gator flat iron the temperature won't stay in the window
Yeah even I think that you should buy new flat iron instead of getting old one repaired. There are some fantastic offers on flat iron on folica.com. You'll definitely like their offers as I found them mind blowing always.
Oct 30, 2012 | ION Irons
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
I have a Kenmore iron that is giving me problems occasionally. Sometimes when i turn it on I get an error code that says "NTCERR". I am thinking that it may be due to the temperature where the...
The message refers to a component that is reading out of the normal temperature range so your theory regarding storage could be correct.
Jul 03, 2017 | Kenmore Irons
THE HEAT CONTROL LIGHTS ARE FLASHING FROM TOP TO BOTTOM CONTINOUSLY. ANYTHING WRONG?
Check to make sure the voltage is normal. Really that is warning sign.
Oct 10, 2010 | Euro-Pro Shark GI490 Iron
Iron saying "error"
my **** is to big for my girls friends ***** how do i get it in?
May 11, 2009 | Black & Decker D2030 Iron
Kalorik STP23783 Iron with Auto Shutoff Logo
54 people viewed this question
Top Kalorik Irons Experts
Are you a Kalorik Iron Expert? Answer questions, earn points and help others
