Question about Dual XD-7500 CD Player
Stereo loses power when vehicle is in motion.
The stereo plays fine when the vehicle is not moving, but it shuts down when the vehicle is in motion. How can I fix this problem?
    Genius:
  • 1,673 Answers
Look for a loose wire or connection! Obviously something is getting disturbed by the bumps and motion of the vehicle.
You would have to get access to the wiring that is associated with the radio, and try moving, pushing, and pulling on the wires and connectors to make some kind of disturbance. They when you make the fault, you work your way around to zero in on the exact location.
Jerry G.
Posted on May 25, 2008
JVC KD-SX990 Stereo randomly off and on
If you've confirmed that it's actually losing power (a CD will start over when the display and sound come back) instead of just the display cutting out, then you should first check your fuse panel in the vehicle, and make sure the fuse that provides power to your radio is seated firmly and securely. Try jiggling it if you can and see if the radio cuts out then. If it seems fine, take the radio out of the dash but leave it connected. While it's powered on and playing, jiggle the connector that's plugged into the back of it. If it's still fine, do the same thing with the wiring harness that's connected to the factory wiring. At one of those connection points (fuse panel, connector at rear of radio, or connection to the factory wiring in dash) you may have a loose connection.
If you cannot repeat the radio failure by doing this, you likely have an internal problem, such as a failing power supply, or it's overheating and shutting itself off.
Sep 14, 2017 | JVC Computers & Internet
Candy crush keeps on crushing even before I start playing
delete app and re install. You will start where you left off. This helped me. .
Feb 13, 2014 | Wheeled Battery Charger - 6/12/24V, 12...
2001 Dodge stratus 2.7 lr. Stereo worked fine, but quit working when a new engine was put in. Radio turns on but the volume won't turn up and only static can be heard through the speakers, however, the...
look in glove box for radio code,it may be in the owners manual. after you lose power to stereo,it shuts itself down for anti-theft. you'll need that code to program into your radio before it will work again. hope this helps and thank you for choosing fixya.com
Dec 30, 2010 | Dodge Stratus Cars & Trucks
Just installed aftermarket stereo in 1995 Ford
The memory (unswitched) wire, usually yellow, is not connected to a "hot all the time" connector...or its fuse has opened.
Jan 07, 2010 | Car Audio & Video
AMP GUARD ON
I'd say go back to the guy who installed and get him to do it right. He's either left some wires exposed so they are intermittently touching, or has an open connection to one of the speakers. The amp will shut down to protect itself. He may also not have wired the speakers correctly. Some systems don't work unless both hot and ground wires run directly to each speaker. Some installers run only a hot line and use the car body for ground. At higher powers this can cause amp shutdown or keep it from working at all. In any case the installation wasn't done correctly.
Apr 22, 2009 | Clarion M475 CD Player
Car shuts off electrically when running for no apparent reason
check out your wiring under your steering column covers. there has always been an issue with those wires getting hot and shorting out or burning up all together. headlights are affected the most but it is sparatic as to what it affects in that harness.
Mar 27, 2009 | 2003 Dodge Neon
I love loud music
i have alpine stereo's in all my vehicles and i have had this problem. if you run a 10-14 gauge constant wire from the stereo directly to the battery the stereo will not shut down in protection mode. it is not the cd it is the stereo going into protection mode because of lack of current not voltage. i hope this helps after i did this i could play the stereo as loud as it can go until my battery died
Oct 28, 2008 | Alpine CDA-9856 CD Player
CDs in car stereo
what make and model stereo. often just removing power to the stereo for about five minutes will reset it... then try it again.
Robert
Sep 02, 2008 | 2004 Subaru Forester
Rca L37WD12YX1
Rebuilt power supply by replacing capacitor on power board ,they are not swolen but if you pull and check them you will find out that they have changed in value.
Jul 14, 2008 | TruTech PLV16260 Television
Powering off
bclion,
I found out that this system only works with some mp3 players in the USB, but you can buy a headphone jack to AUX cable and plug it into the AUX ports and it should work.
Kruddy
Nov 19, 2007 | RCA RS2664 Shelf System
Dual XD-7500 CD Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
