Question about LG WM1814CW Front Load Washer
Water keeps running in
The water does not shut off it keeps running .
  • johnniebacon May 25, 2008
    my water will not turn off it keeps filling the tank to the top
  • 489 Answers
You have a jammed open water valve in the machine and it will need to be replaced.  Call a qualified LG technician to service this problem.
Posted on May 26, 2008
Just hooked up a used bunn omatic the water will not stop running
One of 2 things. The water refill valve or high water probe is bad
Sep 15, 2014 | Bunn 10 Cup Home Coffee Brewer
Why does the Water valve keep running water when bowl is full?
Because the shut off point is above the overflow tube. You will need to either adjust the arm or bend the float end of the arm downward to make the arm end swing higher to reach the shut off point prior to water overflowing into the tube.
Apr 27, 2014 | Korky Waterwise Toilet Fill Valve 528Z
My bolier gas supply is going on and off while the water is on
if the flame keeps shutting on and off while running hot water. it is more likely to be a failing thermal coupler, here is what a coupler does- it is always in the pilot light flame which acts like a thermometer. it goes from flame to the gas control, if it is failing or has failed, it will shut the gas off. as a safety precaution.
Jun 07, 2012 | Water Heaters
The tub keeps filling with water. I must run drain/spin constantly to keep the water from coming out.
Hi There,
Either the hot or cold (or both) water inlet valves has failed and is locked open. Keep running the drain/spin as you are doing and shut off the water supply from the machine. After you have shut off the water supply and the machine has fully drained, switch the power OFF as well. There will be service valves for shutting off the water supply at the ends of the hoses connected to the back of the washing machine. Hopefully, whoever installed it hasn't located the valves behind the machine or you will need to pull the machine out to turn the water supply off - I've seen this done far too many times and it's not clever. The machine will then need to be inspected and will probably need to have at least one solenoid replaced.
Please post back if you need further assistance.
Regards,
BElectric
Nov 30, 2010 | Kenmore HE3T Washer
The water does not shut off it just keeps running
this may not be the answer your looking for, but get a new on, you'll spend well over the 40 bucks that things cost trying to repair it!
Jun 25, 2009 | Hamilton Beach BrewStation 47224 Coffee...
The water wont shut off
Check water valve. Solenoid may be stuck. This is where your hoses attach to, all one unit.
May 25, 2009 | Kenmore 24032\24036 Top Load Washer
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
May 12, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
I have a rule 1800 computerized pool cover pump. As soon as I plug it in, it runs a few seconds then shuts right off, WON"T keep running. (this is outside of the water, dry) any help?
That's a good thing. That pump uses resistance on the impeller to alert it to the presence of water. It will periodically start and run for a few seconds. If there is any water present, it will keep running, otherwise it will shut off until the next time it tries. Put it in water, and see if it works there.
Dec 12, 2008 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Roper washing machine hot water won't shut off
An obstruction in the hot water-inlet valve may mean that it's no longer able to shut off and should be replaced. Good luck !
Sep 11, 2007 | Washing Machines
LG WM1814CW Front Load Washer Logo
384 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
