Question about Apple iBook G4 Mac Notebook
Ibook drive broke down - Apple iBook G4 Mac Notebook
  • 863 Answers
Sell this beast, because the cost and labor to replace the drive isn't worth it. There's like a million screws you got to take out just to access this thing.
Posted on Oct 11, 2010
New hard drive on iBook g4
it is not an easy job to change a HD on an old iBook G4.
you need some experience in handling microelectronics.
step-by-step guide is available here:
https://www.ifixit.com/Guide/iBook+G4+14-Inch+933+MHz-1.33+GHz+Hard+Drive+Replacement/189
iBook G4 14 933 MHz 1 33 GHz Hard Drive Replacement 24100867-eger5opjetenbdaollq52u3v-5-0.jpg
Apr 12, 2014 | Computers & Internet
I can not install viber apple ibook g4.when ever i try to down load i am told the application viber can not supported by this architecture
Hi Christy,
Viber appears to work only with OSx 10.7 and up, which is not supported on an iBook.
When they say "viber can not supported by this architecture", they're referring to the iBook not having an Intel processor like the MacBooks do.
Hope this helps!
Aug 19, 2013 | Apple Ibook G4 14", 1.33...
Reset_To_Factory_Setting on mac ibook g4
Justin I suppose the easiest way to do this would be to insert your system disk into your ibook boot it up holding down the c key on your keyboard and then instal a fresh system. Use the erase and instal option as this will erase your hard drive. Any other queries get back to me, hope this helps. By the way a step by step way of doing this can be found at http://macs.about.com/od/leopard105/ss/installleopard.htm although it's leopard it should be similar across system.
Oct 31, 2011 | Apple iBook G4 Mac Notebook
Extracting hard drive data from inoperable iBook G4 Apple laptop
well there is a solution so first check the type of hard drive in your ibook and check if any of your friends have an ibook, if so replace hard drive with yours and you can extract your data if your hard drive is working.
good luck.
Jan 05, 2010 | Apple iBook G4 Mac Notebook
My ibook G4 has stopped reading my external dvd drive.
If you external DVD drive connects via USB, try rebooting your iBook. (Sometimes a static shock will shut down your USB channel, and only a reboot will reset it.)
If this doesn't work, choose "About This Mac" under the Apple menu, then click on "More Info." Under Hardware, click on USB. See if the drive shows up as one of the attached USB devices. If it does not, the drive or cable may be bad.
If you have another computer available, connect your DVD drive to it. This will tell you whether the drive has failed.
Nov 14, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
My apple ibook g4 will not recognize the charger
It takes a lot of force to break a charger connector in the charge socket, so the connector socket in the iBook will probably be damaged and needs replacing. Take it to a reputable repairer, or, if you have the skills, you can fit a replacement DC In Board.
May 26, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
Dvd will not eject from my iBook G4
Hold down the Apple and the E when you restart your computer.
Mar 13, 2009 | Apple iBook G4 Mac Notebook
Ibook g3 wont startup.
It's probably a problem with the hard drive not being able to be mounted. This can happen when some of the important sectors of the hard drive become corrupted or damaged somehow. The best thing to do is to start with an OS X cd (hold down c after the boot up chime to boot to the CD). When you've done this then cancel the install process and go to tools and use the Disk Utility to repair the drive. I'm guessing that you'll find that it fails because the drive has some serious problems with it.
You can keep trying various stuff, but you'll probably have to reinstall OS X to get it working again.
One thing to try is to use it as a firewire drive (hold T while starting the computer) and then connect it by firewire to another ibook so you can get your Home directory off it and save your data. I'm guessing though that this won't work because the hard drive isn't able to be "mounted" (accessed). Write back if you have more ??s
Nov 09, 2008 | Apple iBook G3 Mac Notebook
Apple iBook G4 Mac Notebook Logo
23 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
