Question about Bosch Nexxt 300 Series WFMC2201UC
I am getting an E02 error. It has been running for about a half an hour and clothes is still dry. Water appears to be going in, but not sure to where???
I've encountered this a few times. I still haven't been able to find out what the E02 stands for, but if you unplug the machine, wait 30 seconds, then plug it back in, it seems to work fine.
Posted on Oct 20, 2010
Hy, I have a washmasine bosch WAE28267SN that sow me an error E02 that's the error. Somebody can help me with some tips Thanks
The E02 error means that the washer is slow to fill. This can be caused by a problem with the incoming water hoses, the water valves or the washer draining as it fills.
The first thing to check is the incoming water if you have very little water in the washer. Make sure that the shut-off valves have been opened fully. If they were fully open, close them. If they were closed, check if that solves your E02 problem. Next remove the water hoses. A damaged anti-flood hose can reduce the water flow to a trickle. Clean the filters at both the shut-off valves and the intake valve on the washer. Replace the hoses at the shut-off valves. With a bucket below the hoses, turn on the shut-off valves and check that you are getting good flow. Now, attach the hoses to the washer. Check if the washer fills properly.
Check that the drain hose is positioned so that the outlet is above the water line of the washer. If your E02 issue continues and no water gets into the machine, then the inlet valve could be stuck in the closed position. If the washer is filling and the E02 error persists, then the water flow sensor may be a problem. This sensor has air tubes that can become clogged. Make sure that they have no dirt. There are other parts in this sensor that could be damaged.
Unfortunately, I don't have a source for parts for this washer. Some Bosch water inlet valves are available here: http://www.appliancepartspros.com/bosch-washer-valve.html . If your washer is under warranty, contact Bosch.
I hope this helps.
Jun 15, 2016 | Bosch Washing Machines
Why are error codes F01, F06 and E2 showing up?
sounds like its not loading water.. this normally occurs if either your pump filter is obstructed or the inlet pipes filters are..TURN OFF THE POWER SURPLY then turn your water off at the stop valves and get the.. hold a small bolw under the joints when doing this as there will be some water in the pipes. with the pump filter id need to know the model to tell you where there filter is located, if your machine has a small panel at the bottom left of the front then its fairly easy if not the pump is at the back.
Click open the front panel you will see a knob similar to that on a mircowave,, turn this gently anticlockwise. ONLYT TURN IT SLOWLY as water will flow out, using a small bowl drain the water out. it will take a few bowl fulls to do this.. when your sure all the water is out fully remove the filter.. and run under a tap to clean of any lint etc, Before replacing put your finger in the outlet you will feel a small fan like device just move it slightly it should rotate freely.. (if not then the pump is jammed or burnt out) when replacing the filter double check for any dirt give it a rub with a sopf cloth and screw back in.. make sure it is in tightly..
Sep 03, 2014 | Maytag Maxima EcoConserve Series MHW6000X...
How to solve Error Code E02 always appear
Error Code E02 means paper jam.
Solution
1. Unplug the power cord and USB cable.
2. Lift the printer upside down, then shake the printer.
3. This is done, to remove foreign objects, which get into the roller.
Causes of damage
Solution
Oct 27, 2011 | Office Equipment & Supplies
I am having a problem with clothes not getting dry. I have made sure that the vent tube is obstruction free the whole run.Also have checked both high limit switches on heater can with ohm meter. Burner...
I know this is basic, but did you check to make sure that the vent hose is not blocked? If the air can't flow out, the effecincy of the dryer is limited.
Jun 17, 2011 | Whirlpool ET8CHEXSQ Dryer
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Seems to work and get warm but takes more than an hour and half to dry light loads of clothes
take the filter out and run it under water, see if the water flows through the mesh. Sometimes there is an oily residue that blocks the holes in the mesh. If it holds water, wash in warm soapy water and try again. If water flows through this time, re install filter and try machine again. I hope this helps
Oct 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My LG dlg2532 takes forever to dry clothes. When the drying cycle ends, the clothes are still quite damp. It's a gas dryer and the dryer seems to be getting gas since it does eventually dry the clothes...
How long are the vents? do they go for miles in your house?(sarcasm) Does the dryer have good ventilation? Check the vents again and make sure it is clear.
May 27, 2010 | LG DLG2532 Gas Dryer
Electric GE dryer DBXR463ED2WW is not drying
The exhaust hose or piping is clogged, try cleaning it or replace it.
Mar 26, 2009 | GE Dryers
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
885 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
