Question about Syntax Olevia 50" Rear Projection HDTV-Ready Television
On 30 min-or all day. just shuts down with solid yellow lite glowing on front panel. can unplug/plug in and it runs again 30 min or all day. in town where made, tempe,az. any tech's left? (has new bulb)
Could be overheating -bad capacitor take a can of compressed air and spray the back. cool one area at a time see if this helps identify the problem area
Posted on Sep 30, 2010
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
When I sit down to watch a movie my system sound shuts off after 3 min. I get up and wiggle the svideo cable and the sub powers back on and is ok for another 3 min or so. it repeats the same chacteristics...
The cord you are wiggling is not an S-video cable, it is a Mini DIN 8 connector. Both S-Video and Mini DIN 8 are the same type of connector, (DIN) except the S-video is a Mini DIN 4.
I'm not sure exactly what the problem is, perhaps you could enlighten me with some more info? Have you changed any audio settings in the menu lately?
First, try unplugging your sub from the power for 30 secs. Then plug back in.
Then unplug one speaker (doesn't matter which one but keep track of what you've unplugged) from the sub, wait the 3 mins and see if it shuts of again. If it shuts off again then plug your speaker back in and repeat this step with another speaker, until you've found the culprit, or run out of speakers.
Let me know what you find.
Nov 11, 2012 | JVC TH-M606 System
Clean lite blinks on front panel. unable to cancel cycle. interrupted power with no help.
Be so kind to add the model and model number to have more info. For the beginning you might want to try the unplug the dishwasher for 30 min. then try again...but if that does not work, you will need to check the control panel.
Jun 04, 2011 | Dishwashers
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
Why would my truck shut down ,, and wait 15 min to cool off and be able to restart ,,and get warm again and shut down again
next time it duz it ... check for spark at the spark plugs eneyone will do .. allso check for pulse at the injector plug .... DO NOT USE A TEST LITE ...... if u don't have a injector noid lite use a meter ... if u no spark and no injector pulse the crank sencer is bad ..... if u have injector pulse and no spark .. the cink switch is bad maby shorting when warm .... happens a lot
Apr 24, 2010 | 1998 Dodge Ram 1500 4WD
I turn on tv shuts off after 30-45min. red lite goes dim
It's likely that the TV will require service since your troubleshooting steps didn't resolve the problem. If your TV is smaller than 30", you may carry it in to the retailer of purchase for repairs. Otherwise, service for your TV can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Nov 19, 2009 | Televison & Video
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Please someone help me with my tv
ok i see alot of these at the shop( i have one in front of me right now) The rca itc22 chasis is bad about this.. If the processor finds any problems it will shut it down. THe big problem it can be one of about 20 different things. As the customer the first thing you can do is unplug the set and leave it of 30 min to an hour. then try it again. ( I have yet to see this work) There are some basic assumptions that you can make.. if you see the light flash then it wont be a fuse. the processor is getting power. This is where a technicain starts his troubleshooting. You said it would shut itself down every once in awile... could be a bad connection or a component that finally overheated then failed. The processor on this set records errors so a technician can read these with special computer interface equipment. repairs on the set generally run 150 to 500. These sets are about 800 new at walmart so you have to make the decision to repair
Mar 04, 2008 | Televison & Video
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
