Question about Maxent MX-27X1 27 in. HD-Ready LCD Television
I bought a dvd player i also i have direct tv not sure if cords are hooked up correctly
  • Maxent Master
  • 8,457 Answers
Read ur DVD player owner manual?The DVD player have a HDMI hub.Used a HDMI cable to hook up the DVD player are the easiest way.The Satalite Direct Tv is working,fine on ur tv right?So don't worry about it.
Posted on Sep 30, 2010
Just bought a Phillips 50" Smart TV. I've hooked up my Sylvania DVD /VCR player to the TV. There is sound but no picture. Please help me!!!!
You did not plug in the Power Cord,
or you did not plug the DVD/VCR in correctly,
or You are on the wrong Source,
or the DVD/VCR does not work.
You're welome.
May 26, 2014 | Televison & Video
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
I am hooking a dvd player to our new flat screen....I hear sound but no picture
at the side of the flat screen there is tv in so check the cord and make sure it goes directly to tv in ok.
May 23, 2010 | Sony DVP-SR200P DVD Player
Emerson Model EDW 2203 DVD/VCR Player
Mar 02, 2010 | Emerson EWD2203 DVD Player/VCR
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
Won't get signal to TV.
Check the usual suspects, like unit is plugged in and gets power, etc.
The first thing is to try resetting the player. While it's plugged in and powered on, press and hold the FF and RW buttons together. This resets the player back to factory defaults.
Now you can go ahead and hook up to the TV. You didn't mention what type of connection you're using but make sure you're using cables you have verified to be working. Start with composite and work your way up through S-Video, Component, and then HDMI. These connections should all be made directly from the player to the TV. Make sure the TV is changed to the correct input and only hook up one connection type at a time.
Resetting the player should undo any setting changes or lockups you may have experienced and testing the video outputs one by one should tell you the rest. If none of the outputs work hooked directly to the TV then the player is probably broken and will need service.
Feb 03, 2009 | Samsung DVD-VR357
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Rich
Nov 14, 2008 | RCA F32450 32" TV
Phillips DVD player, No sound
Swap out the red/whites - loud hum means something isn't hooked up right
Make sure a/v cables going OUT from dvp and IN to tv
Feb 19, 2008 | Philips DVD 622 DVD Player
DVD playback color
When passing the video signal thru a VCR on the way to the TV, you are activating the DVD's "Macrovision" copy protection.  You need to hook it directly to the TV.
Jan 27, 2008 | Philips DVP642 DVD Player
Maxent MX-27X1 27 in. HD-Ready LCD Television Logo
90 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
