Question about Do It Best Bar And Chain Oil
Is there a satisfactory substitute for "bar & chain" oil?
  • 885 Answers
No. Bar & chain oil is made so it will stick to the chain and lubricate and it can deal with the heat generated by the chain. It's also thick enough so it won't run freely out of your saw. It doesn't really make any difference who makes it, just that it's bar & chain oil.
Posted on Sep 30, 2010
Testimonial: "Thanks for reply and appreciated the reasoning behind the answer so I now understand the issues"
Which oil do i use in a ryobi C4620 chainsaw?
Do NOT use lightweight motor oil for that bar! Use only bar/chain oil for it - nearly any brand will do just fine, but it needs to be bar/chain oil. Bar/chain oil is specially formulated to stay on the bar & chain in use - motor oil will fling away & your bar won't get the lubrication it needs.
For fuel mixing, use nearly any brand of 2-cycle oil, which is specially formulated to provide lubrication even when it's mixed into your fuel. Use about 3.2 ounces of 2-cycle oil per every gallon of gasoline - a little more won't hurt (it'll make the saw smoke a little), but never use less. Always shake the gas can just before you refill your saw's tank - shaking helps make sure the oil & gas are well-mixed.
Mar 13, 2013 | Garden
Is 10-30w car oil ??? Okay to use as the Oil on the Chainsaw Bar of a Remington Pole Saw Model 106890-02?
Car engine oil has not got a non fling addative so will just spray off the end of the bar and not lubricate the chain where it does most of its cutting, on the underside of the bar.
Oct 26, 2011 | Remington Polesaw Wizard
What Oil is used for the bar & chain lubrication
Hi khipiercy...
You will use "Bar and Chain Oil" for your chain and bar lubricant...it is specially formulated to be used on chains and bars of chainsaws...
You can buy it at any Loews,HomeDepot, Ace Hardware, etc.
Please take time to rate me
Sep 22, 2011 | McCulloch Garden
What kind of oil do I put into my toro expand it chainsaw?
CHAIN OILER See Figure 18. ? Use Premium Bar and Chain Lubricant. It is designed for chains and chain oilers and is formulated to perform over a wide temperature range with no dilution required. ? Remove the cap and carefully pour bar and chain lubricant into the chain oiler tank. ? Replace the cap and tighten securely. ? Check and refill the chain oiler tank every hour when using an electric power head or every time the engine is fueled when using a gas power head. NOTE: Do not use dirty, used, or otherwise contaminated lubricants. Damage may occur to the oil pump, bar, or chain.
Sep 01, 2011 | Toro Garden
In addition to the gas and oil mixture there is a place for just oil....what do I need to put in there ?
That's for the bar&chain oil. It dribbles onto the chain as the saw runs, lubricating the where the chain slides over the slot in the edge of the bar. Without this oil the chain & bar will overheat pretty quickly, ruining both the bar and the chain.
Good luck
Nov 22, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Oct 09, 2010 | Husqvarna Chain Saw 20" Bar
What kind of oil in the oil tank and how much for the remington electric pole saw ?
Bar & chain oil is the best. You can use regular or synthetic. Some say you can use atf (auto transmission fluid) or sae30 oil. I use bar & chain oil.
Jul 14, 2010 | Remington Electric Chain Saw
Automatic Oiler is not working on my Husquvarna 45
This usually means the oiler hole behind the bar & chain is plugged. you need to remove the bar & chain, clean the body of the chain saw in front of the sprocket/clutch assembly. look for a small hole & clean out using something like a toothpick & wd40 or penetrating oil.
Nov 15, 2009 | Husqvarna Chain Saw 20" Bar
Chain and bar do not seem to be getting oil. Have not had to refillbar oil in a long time.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain oiler stop working
remove side cover,bar & chain.ther is an ob long channel above the bar mounting studs that lines up w/the small holes near the edge of the bar,thats where the oil comes out.clean everything.sawdust gets packed in the holes & stops the oil flow.
Sep 22, 2009 | Husqvarna Chain Saw 20" Bar
Do It Best Bar And Chain Oil Logo
352 people viewed this question
Top Do It Best Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Do It Best Garden Expert? Answer questions, earn points and help others
