I think you should go for repair manual first. After that you can easily repair your car by yourself.I had visited this site past 2 months before for my vehicle and find it quite helpful may be you will also get something useful here.They offer cheap prices and also discount too Best Manuals
SOURCE: 2002 acura tl headlight issue
MAKE SHURE YOUR GROUNDED AND THE BULB IS IN RIGHT SOME BULBS YOU CAN NOT TOUCH WITH YOUR FINGERS BECAUSE OF MISTURE ON SKIN
SOURCE: trying to replace a front headlight bulb on 2001 acura 3.2 TL
Look for the end of the wire retainer clip. Unhook it and lift it up. Remember not to touch the bulb. But if you do, just clean it with a bit of alcohol.
btw - Here's a bit of info from a previous post of mine...
The low beams consist of three parts. The bulb, inverter/ballast and
the ignitor. The bulbs usually start to loose their color long before they burn out.
The inverters/ballasts either go out after a while or take a while to
start up.
Before you spend money on a new bulb, try swapping it with the one on
the other side. You'll need a security torx screwdriver to get the
covers off of the back of the lights. Don't touch the glass bulbs. If you do, just clean them with a bit of alcohol.
If the problem stays on that
side, try swapping the ignitors. They're mounted inside the black
covers.
If the problem is still on that side you've got a bad inverter. They're
mounted on the bottom of the headlight assembly. You'll need to remove
the front bumper and remove the headlight assembly to get to it. (I
recommend you take pictures as you remove things so can put them back
together correctly.)
SOURCE: HID BULB REPLACEMENT 2003 ACURA TL DRIVER SIDE
heres the procedure I uploaded it for you click [b][i]HERE[/i][/b]
SOURCE: I want to replace the low beam bulbs for 1999
just did it tke a breath and put on your small hands!If you r talking about hid bulbs i found aftermarket bulbs at www.moble-emotions.com its best to get both and change them togetherso they match i did only one first and you could see the differance big time.On the battery side the black cover to lightbulb neens to b poped off there r two thumb push tab pry light with a screw driver. on pass side take the 10mm bolt off washerbottle and move aside.(.you need a small hex or starbit to remove the set screw.after u get the set screw off takr both hans and twist hard the cover has a slot as u turn off pull out.there is a hook tab about the size of a paperclip un hook at bottom bulb its fixed at top so just lift bottom to top.remove and replace bulb.(twist out )reverse stepsI also looked at a picture on acurra parts site goood luck i think i did it better than discribing
Testimonial: "thanks, your direction was very helpful..."
SOURCE: how do you replace headlight for 2003 acura tl and how much does
The low beam on my 2003 Acura 3.2 tl is burning pink? How do I fix tis?
