Question about Logitech Cordless Mouse
Ce0682 cordless mouse
A friend gave me his cordless mouse and receiver. I plugged it in but it does not work. Without the instructions, I don't know how to get it to work. Do I need to load a driver. I appreciate whatever instructions you can give me to make it work.
Thanks.
    Genius:
  • 1,689 Answers
The link below is the best place to start. The tech support for your mouse can provide what you need to get it going.
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Jerry G.
Posted on May 25, 2008
Somebody gave me a Logitech cordless mouse without instructions how can I get it to work on my laptop???
Plug in the bluetooth detection USB into the PC and the device will be detected and installed. Now the mouse must have the battery in the unit so that it will communicate to the port and work just like your corded mouse.
Oct 30, 2010 | Computers & Internet
Wireless mouse stopped working P/N 810-000215
There's a couple of things you can check:
1. Check that there are good batteries in the mouse.
2. Check that the connection on the receiver to the computer is good. Re-seat it (unplug it and plug it back in) to be sure.
3. check the synchronization of the mouse to the receiver. Push the button on the bottom of the mouse and the button on the receiver and see if that helps.
If not, then shut the machine down, and start it up without the mouse receiver attached, then plug it in when the login screen or "welcome" screen comes up. it might take a minute or two to sense that it's there, but that should be the final test. I have not had a single broken logitech mouse, and have usually given them to a friend when I upgraded to a newer, better one. If the steps I outlines don't work, then think about replacing it. THere are decent sets now including the MK300 series which I'm typing on now that are economical and have decent range and functions.
Dec 29, 2009 | Logitech Cordless Mouse
Wireless mouse not registering with my computer
When you plug the receiver into the computer, what happens? Does Windows see the device? If it does not then the device may be defective. Most cordless receivers plug into USB ports. Try different USB ports.
May 04, 2009 | Computers & Internet
Pointer on mouse freezing up
at times the mouse will not open somethings it freezes and if I turn it off then on again it will start to worm up I have not had a problem before till this week. I have been using it for about 2mo.
Nov 24, 2008 | Logitech Cordless Mouse
Cordless Mouse #CE0682
The mouse is not supposed to go off when the computer is turned off. But it does have three modes so that it can recognize the power it needs to use: in use mode, temporary not in use mode, and long-term or overnight not in use modes. The red light should flicker in the second mode and should dim in the third mode. If you want to save batteries though, you can keep taking them out.
Oct 27, 2008 | Logitech Cordless Mouse
Logitech wireless mouse
First I'd reinstall the CD software that came with the Keyboard and mouse. Then I'd try the following.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Also check to see if you have enough memory to run all these functions.
Hope this helps. Bud
May 16, 2008 | Logitech Cordless Mouse
I have a wireless mouse. there is anumber on back its ce0682 .cant to get it to work.try using mouseware 9.76 disk to install. can you help.
you don't need any drivers as windows sees it as soon as the usb is plugged in. .
it not unusual for these mice to flake out and stutter and refuse to be seen wireless.
mine died a horrible death right in the middle of a kill.
Apr 26, 2008 | Logitech Cordless Mouse
Cordless mouse and keyboard setup
Make sure the batteries are good.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Dec 19, 2007 | Logitech Cordless Desktop EX110 Keyboard
Cordless Desktop EX110 Keyboard doesn't respond
Look on underside of keyboard there should be a button to push that will transmit to the receiver
1st push the button on the receiver
2nd make sure batteries are inserted in right direction into keyboard then push the botton on bottom of keyboard
that should make it work
Hope that helps friend
Nov 14, 2007 | Logitech Cordless Desktop EX110
Logitech Cordless Mouse Logo
2,081 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
