Question about Lands Phones
My panasonic kx-tg4321bx didn't give connectivity response rather than it gives a message "No link to base. Move closer to base, try again"
  • Lands Phones Master
  • 2,460 Answers
Well, you could move closer to the base, or try this: RE REGISTER the HANDSET. That works every time when our cordless goes stupid.
Carl
Posted on Sep 30, 2010
Can not dial out gives me a message that says no link to base
several things check the base is connected to mains power and switched on.
You have obviously checked to see if it is outof range,and checked the batteries.
If you are using more than one base check that you ar connected to the right one.
Also if you have too many appliances connected to the phone point they won`t run.
Nov 05, 2009 | Panasonic Phones KX-TG5571
Cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Apr 26, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
Phones have no dial tone and a message that says
Unplug base (both connections) and re-plug them again. It works for me whenever this happens.
Mar 17, 2009 | Panasonic KX-TGA560M Cordless Expansion...
My phone won't turn on
unplug it from the wall and wait for about 15minutes
Mar 13, 2009 | Panasonic KX-TG1033S Cordless Phone
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
Jan 28, 2009 | Panasonic KX-TG2357 Cordless Phone
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
PANASONIC KX-TG2431 CORDLESS PHONE
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
Aug 25, 2008 | Panasonic Hybrid IP 12 Key Add-in Mod use...
No link to base move closer to base
Your getting this message because the radio portion of the handset or/and base is not communicating with each other. This can be temporary or fatal. You can try re-registering the handset(s) to the base by following the directions in the manual, its fairly easy to do for any model. If that does not work,and you have more than one handset not working with this problem, then it sounds as if your base needs repair or replacing.
Feb 04, 2008 | Panasonic KX-TG5632M Twin Cordless Phone
Lands Phones Logo
462 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
