My computer doesn't detect my keyboard and mouse but the keyboard and mouse work on another computer. how do i get into the safe mode? or do i need to buy a motherboard?
  • 56 Answers
No need for it just try to restore the computer to a previous date at which the mouse and keyboard were working fine..
you can find system restore in start-allprograms-accesories-system tools-system restore..
hope this was helpful
Posted on Sep 30, 2010
Keyboard wont work
Try booting to safe mode and check if the keyboard has the same problem inside safe mode. if the problem is not present in safe mode, then I suggest that you update the drivers using RadarSync which is an automatic driver updater. It won't provide you with bad drivers.
If the problem still occurs inside safe mode, then you need to check the connection of your computer and the keyboard. If worse comes worst, then you would need to replace the keyboard.
David
Jul 15, 2013 | Samsung NC10-14GW Notebook
My keyboard in my revo rl100 doesn't work
Sounds like the battery in the keyboard is dead. Also make sure you have the wireless doggle that came with the keyboard and mouse plugged into the usb port. You might try plugging it into another port.
I'm thinking your keyboard is dead because of the battery or a virus has hijacked your keyboard.
Try booting up in Safe Mode to make sure it's not virus related. Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option and let it boot up. Safe Mode will look different because the icons are bigger and the screen is darker, this is normal. If your keyboard works in safe mode then you might have a virus that can't function in safe mode.
Mar 25, 2012 | Acer Revo RL100U1002 Desktop Computer...
THE KEYBOARD DOESN WORK
My computer wont recognize new wireless mouse
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top or bottom also you might try safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
hope this helps
Nov 20, 2011 | Computers & Internet
Gateayw gt4010 does not boot up,fan starts auto when power turned on. No post beeps,no keyboard or mouse detection.
check leads from motherboard to hard drive IDE/SATA make sure connections are secure and dust free make sure the keyboard and mouse lead's or usb device is securely seated want to make sure
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if you need more help with this or if i have misunderstood your problem post a reply
hope this helps you
Aug 31, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
Xp usb mouse not detected
make sure the battery is good ((has full charge))also you make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) or if its a lead
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable)) if this fails to fix the problem you could try it in safe mode
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps
Jul 29, 2011 | Gigabyte GA-K8VM800M Motherboard
I cannot use my keyboard and mouse. Something is wrong with my devices
Make sure the keyboard is working in bios. When you boot the computer hit f2 or Del. key to make sure the keyboard is working. Also make a note that the keyboards light blink while turning on the pc.
If you are able to go to BIOS that means the keyboard is working fine.
Boot your computer in safe mode by tapping F8 key while the computer is booting. Select safe mode and check if the keyboard and mouse is working in safe mode.
If it is working in safe mode. Do a system restore to a date where everthing was working fine.
Please revert with the result of above .
Sep 01, 2009 | HP Computers & Internet
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
May 19, 2009 | Dell Computers & Internet
Unable to start in Safe Mode with Command Prompt in XP Media Center 2005
Hi there. My name is Alex and I am here to help solve this problem
Depending if the BIOS has legacy USB support for keyboard and mouse enabled, you should be able to run safe mode by pressing F8 before the computer boots into windows. I would not recommend going into the BIOS if you do not have much knowledge to the computer as one wrong configuration could cause some behaviour problems or even damage to the pc's components
I recommend connecting a keyboard and mouse that have cable and the PS/2 connectors (purple and green) which can be found at back of the computer at the top. Then restart your computer, hold down F8 and you will be able to run safe mode. The mouse and keyboard will then work
Keep both the keyboard and mouse plugged in and boot windows. When you get into windows, plug in the USB keyboard and mouse into a USB slot and wait whilst it detects it. After a couple of minutes you should be able to use your USB mouse and keyboard and take out the PS/2 keyboard and mouse
I hope this has helped. Please let me know if you have any questions or need further assistance.
Oct 03, 2008 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
