Question about RTO Atwood Water Heater - 6 Gal LP
Purchased a new replacement tank for my Atwood G6A-8E water heater, how do I install metal retaining rings?
5 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: atwood rv water heater model G6A-8E heats water to
Normal causes for that would be by-pass valve not in proper position, or defective, allowing cold to mix with hot, or thermostat not touching up against tank properly, or defective. Do you know where that thermostat is?
Look where the black foam cover is, with white letters, below pressure relief valve. One is lettered ECO, other THERM. If you note where the wires go, so as not to mix them up , and pull them off, then peel back the foam cover, you'll see 2 little round discs, that are held against the tank by a small spring. They need to be checked that they are in there properly and are up against the aluminum tank.
Posted on Apr 25, 2010
motor1258
  • 6674 Answers
SOURCE: Have an G6A-8E Atwood water heater. It Starts fine...
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
Posted on May 26, 2010
  • 57 Answers
SOURCE: I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Posted on Jun 07, 2010
motor1258
  • 6674 Answers
SOURCE: I am looking for a
Very simple, do you have a 12 volt light tester, or multimeter?
First thing to try is to remove the thermal cut-off from circuit and try it. That's the little diode like thing inside the plastic sleeve below pressure relief valve. Remove it from the circuit and hook female spade from end, directly to thermostat where other end was before. If that does it, replace thermal cut-off.
If not, start testing for 12 volts when trying to ignite, from one side of thermostat, then over to ECO, or just go directly to gas control connection. If 12 volts getting to gas control, thermostat and ECO are o.k.
Are you getting spark at electrode?
Posted on Aug 28, 2011
Atwood g6a 8e
The yellow is caused because the flame does not have enough oxygen. Per your explanation that is being caused because the exaust is not working. Fix the exaust problem and it probably will begin opperating properly.
Mar 23, 2014 | Water Heaters
G6A-8E Water Heater will not start.
x8h3rkvosvawaaaaabjru5erkjggga=
You may need new circuit board, call mfg they may offer more help in determining if a new board is needed.
Good luck
Oct 28, 2017 | Atwood LP Gas Water Heater 6 Gallon 96121...
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
ATWOOD WATER HEATER
you will need to have a 115 curent for electric, run a line off the panel box, turn off water to the house drain it down, disconnect the lp gas line and cap it off, remove the water heater, install the new heater run the cold side water to the cold side {blue on the heater} the hot side to the red, take the cover plate off on the water heater run the wires, hook up the groung wire then the red and white wires to the wires comming off the panel box,, fill the water heater with water have a open faucet on the hot side, and bleed the air out, DO NOT TURN ON ELECTRIC TILL THE AIR IS OUT OF TANK AND WATER IS FLOWING THRU COMPLETELY, after you get water commming out of the faucet turn it off and turn the electric on to the water heater ,, wait about 30 min, you will have warm after an hour it will be hot and you are done,, good luck write me if you have questions, gary1121@aol.com
Jun 29, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
186 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
