Question about Coleman Powermate Powermate 5000W Generator
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V receptacle outputting 355V. 120V receptacle outputting 155V. How can this be rectified?
    President:
  • Coleman Master
  • 1,388 Answers
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Posted on Sep 30, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How do you remove the start stop switch mounted on the rope pull housing on the coleman 5000 powermate 7500 watt unit. You can't get the housing off without removing the start stop switch.
without seeing it, they usual have enough lead length to allow the cover to be moved so you can get to the wire, The switch usually has a blade with a slide connector that can be removed.
Oct 12, 2014 | Coleman Powermate 5000 Generator
Where can I buy a wheel kit for a Coleman Powermate 5000 Genterator ?
Do an online search. I bought mine that way years ago.
No, I have no idea where.
Aug 26, 2014 | Coleman Powermate Powermate 5000W...
I have an opportunity to purchase a used powermate maxa 5000 er and a used transfer switch that it was used with. it is a 6 circuit type box. i was suprised to see that the generator was old enough that it...
There is no reason not to use the plug... it may vibrate out though...that's what duct tape is for...:-)
The electrician should hook it up,, I would no problem...those tranfers are apiece o cake....
I say go fer it...
heatman101
Aug 29, 2010 | Coleman Powermate Powermate 5000W...
Three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Apr 01, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Jan 16, 2009 | Coleman Powermate Premium Plus 6250W...
Oil for Coleman Powermate 5000 PM0545305.03
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
503 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
