Question about Guardian Rv Generator 4800 Watt, Gasoline, Primepact 50G
My generac 40g rv generator will start fine but no power. I noticed that when it starts the microwave will power up for just a second. I can turn the generator off and on a couple of times and then it will power up. Whats up with that?
  • 38 Answers
It may be demagnetised. If you turn off the generator before unplugging the load this may happened. Try to put a strong magnet (like those from loudspeakers) in contact with the body of alternator. I do this in the past and it work.If you do not know how to do this ask an electrician, he can help you .
Posted on Sep 30, 2010
Generac guardian rv generator starts and runs but after a couple minutes the power stops.....generator still runs??
Usually the generator will shut down if the ac is not present coming out of the generator. You stated that it still runs but no power on the output. Check your breakers first to make sure they are working properly. Depending on what board you have you can check to see if ac is present getting back to the board as well. If your board does not have this then they are using the frequency as a safety disconnect feature. That would lead you back to the regulator or loose connection or..dirty slip rings if this unit has brushes.
Oct 25, 2017 | Generac Electrical Supplies
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
I have a generac mc alternator model -38 6938 my voltage pulsates underamload just started any ideas
Cleaned and adjust carburetor per Repair Manual. then adjust governor repair manual and should take care of problem on this old generator.
https://www.generator-parts.com/manuals/generac-rv/051834.pdf
Jan 07, 2015 | Generac Electrical Supplies
Generac generator manual
Usually generators that have stood for a very long time loose the magnetism in the ignitor coil magnet. With care, if you can find the low voltage wire into the generator 'motor' you can apply a 9v battery briefly to it and spark it into life. Use the generator if you get it generating, for a good period and don't leave it unused for a long while.
*IF YOU DONT KNOW AND UNDERSTAND ELECTRICITY DO NOT TRY THIS. GENERATORS CAN KILL*
Jul 31, 2014 | Generac Power Systems Generac 0057500 75...
Guardian rv generator starts popping when turning on hair dryer. Why does this happen?
What is the wattage of the hair dryer?. It sounds to that your hair dryer is drawing to much power for the generator.
Apr 19, 2013 | Generac Guardian Electrical Supplies
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
Generac NP 50G Stops after 2-30min.
check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
Oct 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Guardian Rv Generator 4800 Watt, Gasoline, Primepact 50G Logo
561 people viewed this question
Top Guardian Electrical Supplies Experts
Matt Olenzek
Matt Olenzek
richie46
Are you a Guardian Electrical Supply Expert? Answer questions, earn points and help others
