Question about Omega Reliance& Electric Compact Water Heater
Hi, I would like to know the omega water heater the model no. so-80 body test pressure please give and solve this problem Thank you, regards, Diwan khan
GE water heater Model # GG38T06AXK00 pilot will not light
We are a local plumbing and drain service that sees these types of failures on these types of water heaters all the time. Call us today for your free in home Estimate. We are affordable, & offer same day services.
(Let us know where you found us for your Discounts)
Alpha Omega Discount Plumbing & Drain Services 661-836-8813 Bakersfield, 661889-2625 after hours
Licensed #945568 BBB Accredited
Jan 12, 2012 | Water Heaters
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Loud vibrating sound coming from hot water heater. Had gas company change meter and regulator. At first was losing hot water while in the shower. Went through check list after it coded out at #12, all...
Can't address other issues, but WATER pressure should be 40 to 80(I'd say 70)lbs. tester at home D for $10-15. Goes on hose Bibb outside, or at washing machine cold valve.
Mar 18, 2017 | Rinnai Water Heaters
I have a richmond power vent water heater model number 6G40POW-40F.It will run for 2 min then shut itself off then restart and do the same thing all over.Then 2 lights come on and it wont run. Any help...
Fastest way to solve water heater problem is call plumber or service technician.
Open following link for typical error codes for intellivent gas valve found on newer Richmond/Rhemm power-vent gas water heaters:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
There is no 100% sure way for novice to repair gas water heater.
This is because electrical parts have to ohm-tested using information from service manual that is typically not sent with new water heater.
Also parts have to be cleaned. The gas pressure checked, air in gas line removed, burner tubes and pilot tube and combustion chamber cleaned, burner parts inspected for problems, air intake cleaned, exhaust vent tested.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Best way for do-it-yourselfer to solve water heater problems is to learn as much as possible about specific model by reading product manual that comes with new heater.
The manual will show error codes.
Then keep up with yearly service recommendations shown in manual.
Aug 03, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Hi i have a power vent water heater model #-6g40pvw-40f. It go's into lock down mowed one light lit on vaction two more on A-and B is it the heating element or lighter mechanison thank you mike from...
Hello Mike,
Check gas pressure, burner parts need to be cleaned, check electrical outlet, hot surface igniter is bad
White Rodgers intellivent error code:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
Error code says: system in lockout, but you know that.
1) Low gas pressure, no gas to water heater: call gas company to check pressure
2) Hot surface igniter not positioned correctly: inspect and clean burner parts.
http://waterheatertimer.org/images/Reliance-hot-surface-ignite.jpg
3) Low voltage to water heater/ outlet has wrong polarity: Use circuit analyzer on electrical outlet to make sure polarity is correct
Typical power vent manual:
http://waterheatertimer.org/pdf/Reliance-40-50-power-vent.pdf
Cleaning water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
http://waterheatertimer.org/pdf/How-to-clean-combustion-chamber.pdf
Jun 19, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Need to know minimum and maximum manifold pressure settings for a rheem tankless water heater. Model # RTG-74PVN-1
Please review the Rheem water heater manual below. Page 18 will give you the manifold pressures.
I hope this helps you...Jim....Please leave a comment if this information helped.
http://www.heater-home.com/manuals/DirectVentManual.pdf
Feb 13, 2011 | Rheem Water Heaters
I have a warrior glass hot water heater.model number 71-305.serial number r 0590822159.wattage 240 volts ac only. 30 gallon.the water pressure is low.drained tank to clean out.still having problems.any...
Buy a pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Test pressure on water heater drain valve.
This will tell you if the pressure problem is before -or- after the water heater.
If problem is before the water heater, then the shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in the hot water outflow pipe on top of water heater, or a nearby elbow.
Nov 11, 2010 | Rheem Water Heaters
I unfortunately own a Omega 2000 Group tankless
E2 is the overtemp code. Unfortunately, the Omega line does poorly with single-handle faucets. Don't bother George Sararu, he just bought a container of these water heaters and knows nothing about plumbing. There will be no repair parts you will need. Either toss it now and get a tankless from a local dealer, or wait until your Omega unit is totally useless, then go with a local guy. George conned a lot of people - including me. I own 2 side-by-side in the utility room and figure one more year until they are junk.
Since I'm on a well, they have to be seasonally adjusted to compensate for groundwater temps. Big pain, should have bought Rinnai.
Sep 03, 2009 | Bosch & Tankless LP Hot Water Heater
Omega tankless water heater giving error code E2 incomplete burn
it sounds like your flu pipe may be clogged,, they just snap together or have little screws holding them together,, take the sections apart and make sure nothing is is the line reinstall and try it out
Jul 06, 2009 | Omega Reliance& Electric Compact Water...
Omega Reliance& Electric Compact Water Heater  Logo
142 people viewed this question
Top Omega Water Heaters Experts
Donni Steen
Gil Shultz
Are you an Omega Water Heater Expert? Answer questions, earn points and help others
