Question about Xante Ilumina Digital Color Press Printer
Problems feeding 70# announcement envelopes-5.5 bar. Jamming in the fuser
  • 24 Answers
2 things.
Fuser is worn, even if % says still has life, but if less than 40% say, then fuser could be slipping.
next with the lid up and fuser removed, look to the left of where the fuser sits in the centre between the exit rollers, there is a little black lever pointing up about 1/4 inch. if it's not there, it's broken off, usually from pulling back a papr jam in the wrong direction (enmvelopes can snag on tghis if pulled back in opposite direction of feed...if you can find the broken bit, it can be superglued back in place very carefully, esle yu need to get a a techie in to replace.
Posted on Nov 12, 2010
What is thbest hp printer for printing envelopes.
The best way to deal with envelopes is to either get a label printer like a Brother, or get laser safe window envelopes. Envelopes cause many problems and if you are going to print a large number of them you will wear out the fuser prematurely because the outer edges of the fuser will overheat feeding the narrower paper.
Oct 19, 2016 | HP Office Equipment & Supplies
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Paper jam
You're not giving me alot to go on for your trouble. Your're not telling me where the paper is stopping at. There are several problems you could be having. If the copier is feeding from the top cassette and jamming or even not feeding at all then the feed rollers could be the blame. This could be the reason for the lower casette jamming. If the paper is stopping in the fuser then there could be damage or no rotation of the fuser rollers. This should give you an E007 error code. Then the fuser must be rebuilt or replaced. Hope this gets you started. Good luck.
Dec 06, 2010 | Canon imageRUNNER 2000 Copier
Printer prints addresses on paper, not envelopes, even though I click all commands correctly.
make sure you feed in the envelopes correctly and adjust the guides to fit the size of envelope you have in the manual feed or paper tray verses the size of envelope you choose in the print settings from the application you are using (MS-Word) e.t.c, also make sure that envelopes have the correct paper type and design for printing i.e( without metalic clips, not too thick to pass through the fuser)
size 10 is usually easy to go through for example.
Dec 03, 2010 | HP Photosmart C5580 All-In-One InkJet...
How do I print an envelope with my MFC 240C?
Printing envelopes is tricky. In the MFC-240C, you have to place them face down (with the flap side facing up), and it's best to load one at a time because sometimes the printer has problems pulling it when there is a stack of envelopes in the paper tray.
Make sure the fences are snug against the envelope when you load it. If you get a lot of jamming when trying to feed envelopes, you may have to run it with the flap open -- sometimes the closed flap sticks up just a bit and gets caught as the envelope is fed through the machine.
To orient the addresses correctly on the envelope, you'll need to use the correct settings, depending on which program you're printing from. In Microsoft Word 2003, for example, there is an Envelopes and Labels option under the Tools menu (click on the Letters and Mailing submenu) that you can use to enter the addresses and make sure they line up.
Apr 15, 2010 | Brother MFC 240C All-In-One InkJet Printer
#10 envelope stuck in machine
Please try these steps:
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Office Equipment & Supplies
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Envelope feed problems
The problem is due to the type of envelope materials you are attempting to print on. The envelope stock (paper) is much too thin or lightweight. This is the primary cause of the wrinkling.
I would suggest that you switch to a heavier envelope material, but try to stay away from linen envelopes, as these will tend to wear down the fuser mechanism faster that normal. Most printers and copiers all have this classic problem.
I worked as a design engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times over and the only available solution is to change the stock. I (KMA) did work with a company in Canada who developed a specialized mass envelope feeder system for many of our systems. However they made major design changes to the feed mechanisms and feed roller pressure to deal with lighter stock materials.
Hope this information helps you out.
Cheers,
Keith
Oct 22, 2008 | Canon imageRUNNER 5020i Copier
139 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
