Question about HP Computers & Internet
Can I remove the hard drive with XP from a HPa350n computer and install in an e-Machine ET1331G -05W running Win 7
  • HP Master
  • 4,350 Answers
WEll, yes, but there may be connection issues, as most newer units no longer use the ribbon cables of yesteryear. You need to change the jumper to SLAVE on the drive. You can also get USB hookups that will accept and access external drives.
Posted on Sep 30, 2010
Testimonial: "Advised the problem I may encounter and suggest another method Appreciated the advice Thank you"
Transferring an xp3 pc image to a computer presently using Win 7
You might be lucky, but I don't think it will work. If the hardware is different XP will complain or simply not work.
Why do you want to transfer XP on to a machine that is running Windows 7. Win 7 is much more stable and is still supported.
Dec 30, 2017 | The Computers & Internet
Backup Win XP in Fusion to external hard drive
you will see a Removable media on the My Computer window
Aug 05, 2008 | VMware Fusion Full Version for Mac
Tip
Dual Boot Xp & windows 7
First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition)
Now install xp first in one partition. If you have pre installed then avoid this step.
Now install Win 7 in another partition.
After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7.
You have to format win 7 before installing Xp.
Commiting any of trick or Tweak you need to backup your data in another HD partition
on Mar 10, 2010 | Computers & Internet
Can I change my windows 7 computer to XP with an XP disk
yes --
But you will loose all of your files and folders when you format the hard dive to install win xp
you cannot run 2 operating systems on the one hard drive unless the hard drive is partitioned ( in effect having 2 hard drives on the one disc) as it causes massive conflicts in operation
Why any one would install an out dated , unsupported operating system like win xp in place of win 7 beats me
of course if you insist in doing it you could always install and extra hard drive in the computer and run it as an extra hard drive and install the win xp on it and still retain all of your files and folders
Sep 09, 2017 | Computers & Internet
Emachines et1331g 05w
Emachine website is Download Center ALL Products No BIOs update for it is listed for the 3TB problem. But back in the days of the 1 Gig problem, we would just make different partitions to get around the problem. Might work as well here. If you installing a new harddrive do a clone of your old one. It will make a copy of all your current harddrive info and layout onto the 3TB drive. Just larger partitions if you need help on doing this just ask and give the brand and model. So I can look up the software from the manufacturer. Also state one brand of the old drive.
May 27, 2014 | Computers & Internet
Data on clickfree is from my old XP, when i connect to my newer windows 7 computer, it wants me to format.
Win 7 doesn't recognize the format of XP drive. Put the Click drive on an XP machine on the network and copy files you need then format on Win 7 machine.
Mar 29, 2014 | ClickFree HD535 hard drive 500 GB USB
I bought a LENOVO B 450 laptop. The dealer installed WIN 7. But in WIN 7 Tally 7.2 will not work. So I wish to install WIN XP. But when I tried to install WIN XP there shows an error message and a blue...
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
Aug 13, 2011 | Computers & Internet
Dear sir/mam I want to install win xp in a win 7 installed laptop, (compaq 510) but there was some error to install it (blue screen error). Sir please help me to install win xp the same system with...
You cannot downgrade Windows 7 from Windows XP by not reformatting the hard drive. You need to Remove Windows 7 first, before installing Windows XP Operating System. In order to use the Windows XP CD to fully reformat the Hard drive, follow the steps on the link below.
http://www.windowsxpprofessional.windowsreinstall.com/indexinstallguides.htm
Apr 04, 2011 | Computers & Internet
I am dumb on computers. Want to put case fan on ET1331G-05w. Don't know what to buy. Then where do you plug it? Thanks
Hello materman, click here: http://www.emachines.com/products/products.html?prod=ET1331G-05w This website will show you all the specifications of the "Type & Model" eMachine that you have, this way you can use the "specifications: size, type, and measurements to figure out what kind of "Fan" to install. The most important thing to be aware of is the "Measurements" if it don't fit! You can't use it. There are various :speeds, power needed, this will go by: "Voltage & Amps needed, or requirements. I think you get the idea; thanks for using Fix' Ya, take a look. "Good Luck! paulof9
Dec 11, 2010 | E-Machines eMachines Desktop PC
I have an emachines-ET1331G-05W. I want to install a new DVD drive( LG-GH22) but the wires in the computer dont match connections on back of drive. Do I need to get a different drive or are there adapters...
I think you may have a SATA DVD and your "Old" machine is IDE, SATA is a tiny connector and a slim power plug. IDE is a long slot full of pins and the Usual white power connector. Either that or vice-versa, in any event, either get a proper replacement, the best, or you can get converters for your drive. Ebay has them. they are called USB to SATA/IDE dongles.
Feb 10, 2010 | Computers & Internet
Computers & Internet Logo
143 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
