Question about Canon imageRUNNER 1330 Laser Printer
How do I reset toner /drum ctg code on a canon imagerunner 1330
muleskinner2
  • 270 Answers
SOURCE: having trouble replacing waste toner receptacle on Canon imageRunner 3750
If the copier indicated to empty the waste toner you will have to reset in the counter in service mode. Press the additional functions key, the 2 & 8 keys at the same time, then the additional function key again. This should get you into service mode. If not depress the reset key and try again. Once there at the top right you will see counter. Depress it then you should see a menu and depress MISC. Depress WST-TNR, then depress "C" on keypad. Counter should go to all 0's. I think that the waste toner message displays at 250,000 copies made.
Posted on Feb 12, 2008
muleskinner2
  • 270 Answers
SOURCE: Canon ImageRunner 4570 gives me an error code:E000001-0010
If after resetting the error and you still get the error code than the fixing film for the IR-4570 will have to be replaced and the error will have to again be reset. The part that is supposed to be getting hot is bad and only that part will need to be replaced.
For the IR-5070, the error code is that the heater is not getting hot. If the error has a 0000 sub code then the thermistors may need to be replaced or the DC Controller. Most likely the heater itself is not bad because thay should last the life of the copier. Try doing an error reset by going into service mode. Additioan function key, 2&8 at the same time and then Additional function key. Slect copier, then function, clear, err. If it goes back into the error the above items may need to be replaced. Good Luck. 0010 sub code is that the copier has been turned off and on without restting the error.
Posted on Oct 17, 2008
  • 3 Answers
SOURCE: resetting maintenance ctg for canon ipf8000
unfortionatlly there is a microchip on the back of the cartridge and it is looking for a new one. u will need to replace the cartridge by taking the machine offline then pushing the menu button, scroll down to maintaince, then right arrow to maintenance cartridge replacement then selct yes then ok. then replace the cartridge. sorry, but hope it helps
Posted on Jan 20, 2009
iservice
  • 318 Answers
SOURCE: Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Posted on Feb 02, 2009
  • 79 Answers
You can reset it from the service mode it will take you 15 sec but you can use it only for service reasons.
If you reset it there is danger to fload with ink and messed up the whole area.
Posted on Feb 24, 2009
Waste toner full prepare new drum ? how Where?
On the left hand side of the machine is a blue latch that when you pull it out the whole scanner section will slide to the left. After you get it to the left as far as it will go there is a blue door on the right hand side and under it is the drum and it just lifts out.
Oct 25, 2012 | Canon imageRUNNER 1330 Laser Printer
E000020 01b0
Yellow Drum Cartridge or bad toner. If your using generic toner it can cause this code. If generic toner is used drum cartridge unit will have to be replaced and Canon Genuine toner used instead. Yellow seems to be more suseptable to this than the other colors for some reason.
Nov 25, 2011 | Canon imageRUNNER C3200 Copier
Canon IR C3220N--error code E000020-01b0
If the drum units have been removed repeatedly without the drum guide service tool it's possible to break one or both tabs .These tabs open the toner hopper when the drum unit is slid in, and if they are broken, toner will not be fed into the drum unit.
NOTE: The unit may work for a while until the developer to toner ratio drops enough to cause an error.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Canon imageRUNNER C3200 Color Printer
Our Canon ImageRunner 400S says to replace the waste toner container. However, I can't find in the manual how to do that.
Waste toner is located in drum unit, look for any cork on drum unit assy, open it, and empty waste toner.
Aug 03, 2010 | Canon imageRUNNER 400S Copier
Error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
May 19, 2010 | Canon ImageRunner 2020i Copier
HOW TO REPLACE THE DRUM?
Laser printers usually have toner cartridges that include the drum.
You can purchase new Canon toner cartridges or recharged cartridges, these are approx. half the cost of a new one.
Nov 27, 2009 | Canon imageRUNNER 1330 Laser Printer
Blank scans- canon imageRunner 1023N
Blank image = transfer/separator unit/corona is not working. Please check the transfer unit.
Aug 19, 2009 | Canon imageRUNNER 1023 Black and White...
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Canon imagerunner 2010f wont print
You may need to go into service mode and reset the drum status. Service mode is dangerous and recommended for Canon techs only.
Aug 25, 2008 | Canon imageRUNNER 2010F All-In-One Printer
Canon imageRUNNER 1330 Laser Printer Logo
149 people viewed this question
old marine
old marine
