Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Water circulation is OK. barracuda g3 does not pulsate, hoses are clear
    Novelist:
  • 116 Answers
If the cleaner is not pulsating, then either you don't have enough suction or the diaphragm is bad or clogged. Very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. Your cleaner should have come with a suction gauge that you put on the end of the hose in place of the cleaner. It's a clear tube with a spring and plastic piece inside that indicates high, low, or normal. Use this to check your suction. If you don't have one see if you can get one at the local pool supply house, they may even have one you can borrow. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Sep 30, 2010
Pump quits sucking water when barracuda plugged in
you must prime the hose with water before connecting the cleaner, hose might also have holes in it, look for leaks
Aug 05, 2013 | Zodiac Baracuda G3 Automatic In Ground...
My barracuda is not moving and i fell is not pulsating eather why?
If your pool cleaner is moving slowly and not pulsating, there are a couple things that you will want to check and/or adjust. Make sure that the main drain is closed. It is a common problem with these pool cleaners not operating correctly if the drain is not closed. Use your flow gauge to make sure that there is adequate flow. Poor water flow through the cleaner can cause these problems. Backwash the filter and clean out any skimmer baskets. Clogs can cause loss of suction and prevent movement. Make sure that the diaphragm is not damaged. Check for hose leaks and air entering the line at all connections.
Apr 02, 2011 | Zodiac Baracuda G3 Automatic In Ground...
New g3 i straighten out the hoses, connect up barracuda,the hoses twist all back up,and it stays in one place
Try disconnecting all the hoses and laying them out in the sun for a few hours. The heat should loosen their shape. Then make sure to not reconnect in the same order. The hoses develop a "memory" if bent in the same position over and over again. If all else fails buy new hoses, although if it's new that shouldn't be the problem.
Oct 16, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My zodiac g3 does not cover the entire swimming pool
One of the most common problems with these pool cleaners is the hose. If the hose is not long enough, it will not cover the entire pool. You might need additional hose. Also, make sure that your hose is weighted correctly and the water pressure is correct.
Aug 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda is pulsating and moving but surfaces
The control should be below the water, and if you cut the suction down that should help with the cleaner.
Dec 22, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda Zodiac G3 is not pulsating. It's got
either some debris is caught in the diaphragm or it's deformed enough to render it inoperable. Unthread the nut just above the handle and pull it apart, then push the white tube downward until it comes out of the bottom of the unit. Inspect the diaphragm to see it there is any debris in it or if it is deformed. Usually the diaphragm has a uniform opening, if the gap is wide, it will not function. The most common problem is that the diaphragm needs replaced. Hope this helps.
Nov 16, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
620 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
