I have an MSI A6000 laptop. This is the problem: I am doing a system recovery with using 2 disks my laptop burned. The first disk worked fine. I placed the second disk, and the laptop does not accept it. What should I do? I don't want to shut it down, can't find another recovery disk to download. Please help with suggestions!
  • rigali2000 Sep 30, 2010
    Thank you for your suggestions. However, I haven't been able to find an option to download the recovery discs from msi. The problem is: I burned my 2 recovery disks. The second disk was rendered successfully (at least that is the notation upon completion). Now, that the 2nd recovery disk is rejected (acts like it is not in the disc drive)... I get: bootmgr missing.
    I have a repair disc widnows 7 32 bit, but it does not fix the problem. It offers to load driver for OS, but it's cryptic.
    If I could only "just download" recovery discs for my msi a6000 laptop... I'd be good to go. I don't have a back up image... my recovery disks is supposed to be that image, but is rendered with error. :(
    I tried the boot menu, but the Recovery partition is non-accesible or non-existent. I believe that when I began to restore my computer to factory settings... it began to format the hard drive. The problem is, msi rendered my 2nd recovery disk with errors, I suspect, but notated it was a successful outcome (which obviously is a lie and a kick in the pants!)
    If I can boot my computer to install an os, that would be helpful Can you send a link to download an image to burn a disk using nero so that I can make a bootable operation system disk on my other pc for my msi laptop? I would be thankful to try that option!
    Thank you for your time and help!
    disc drive)... I get: bootmgr missing. I have a repair disc widnows 7
    error. :(
    pants!)
    Genius:
  • 1,035 Answers
Hi. Are this recovery disk came from the manufacturer? If you have another computer, you can checked the files inside the second disk. You might have the same disk. Usually disk 2 is driver and software disk. Disk 1 is for the operating system.
Posted on Oct 01, 2010
  • 4,924 Answers
Go to bios and select the boot order from the disk ..and try again ..a few times..maybe this is the issue cause it tries to boot instead to get the booting from the second disk ..
if the disk is not accepted it means that you had an error when you burned it ..and in this case the way to do it is to install the operation system from a bootable cd with the operation system ..and after that install all drivers from the support site ..
or go to the suport site ...download the recovery disks again ( I guess will be the same ..and burn other 2 disks and used it again from the start )
also you may check if you have a recovery partition from the factory ..Im not sure what is the boot menu button on this model ..but if you know it ..press it on start and if a recovery partition is existent on the hdd from the factory ..you can use it by booting again from it ..
Or let me know what operation system you want to install ..and I will link you to a download with an image to burn a disk using Nero and make a bootable operation system disk ..and the drivers you can get them from the support site ..I see no other way ..
If you still have the image with the recovery disk that you burned on some storage ..just burn again the second disk ...on other computer cause the one that is not accepted might be damaged ..
Posted on Sep 30, 2010
My msi A6200 laptop goes thru the installed things again again. Won't let me go to recovery or reset... help. What keys do I press
Hit the F8 key during the bootup and if menu pops up select "last known good bootup" and hit enter - see what happens.
Or use the recovery disks that came with your unit or that you were supposed to make. If no disks you may be able to purchase from MSI. Otherwise you will have to do a clean install of the OS from regular install disks.
Dec 03, 2015 | MSI Computers & Internet
Make recovery disk for acer extensa 4630z?
If you have precious files on your HDD and it's inaccessible at present I would download a copy of Puppy Linux and burn it to CD (or buy one off ebay for 2 euros). Boot off this and browse to your HDD, copy files to a USB memory stick if you have one. I assume you've tried SYSTEM RESTORE in Windows and it isn't accessible or doesn't work. If this is so, you could try ebay for these extenza recovery disks. Failing that you should use your Windows installation disk to do a REPAIR INSTALL (Google for instructions). If you have not got one you could buy one from ebay for your OS but that could be costly. A cheaper way is to buy one of the many system restore disks available on ebay but you will risk having malware. Good Luck
Dec 17, 2014 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Msi ms1719, where can i get a recovery disk for this laptop
a pc mechanic will have universal or multi purpose recovery disks.... you should try getting a windows boot disk and just doing a system refresh, u can buy from best buy or a pc mech
Jun 17, 2013 | Computers & Internet
How do i do a system recovery without a disk
Try This . When the System CD and Recovery CD are not available, you can create them by
using this feature.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery window, select Recovery settings and click Next.
5 In the Recovery settings window, select Burn image to disk and click Next.
6 In the Burn image to disk window, select 01. Factory default image and
click Next.
7 Follow the instructions on screen to complete the process.
Jun 24, 2011 | Acer Aspire 5500 5570-2609 Laptop
My smartbook does not want to turn on because of a error saying '' Application explorer exe. error '' what should i do?
you can recover your windows by recovery disk (if you have a recovery disk, due to specification of your notebook, it's use windows xp which has built as your original os, it means your notebook has a recovery disk) but you will lost your data in drive C (drive contains your operation system)
turn on your notebook
press f3 immediately from your keyboard
select MSI recovery manager
press OK
wait until the process of system recovery finish
Jun 05, 2011 | MSI Wind U100-016US Laptop
While I was trying to burn a back up recovery disk for my emachine's windows vista, emachine didn't come with one, but a program on it to install one. I was told to use 10 writeable cd's or 2 dvds, i...
The problem here is that when disk burners stopped being $400 each, the quality went way down. What's likely happening is that your burner is sucumbing to an alignment or heat-related issue. My gut feeling tells me that you should do the burn, then wait about an hour (maybe two) and do the second disk so the electronics and mechanical parts have time to cool off.
[rant] The real issue in your case is that eMachine's recovery system is an after-thought. Any well thought-out system would let you select which disk to burn or give you the option to make ISOs so you could burn them on another machine. More importantly, they should just let you do this to an 8GB USB stick and call it a day. I would avoid machine that can't be bothered to give you an easy way to recover their machines, then give you the responsibility of creating the recovery media on sub-par hardware. [/rant]
Anyway, let me know how it works out.
Feb 28, 2011 | Computers & Internet
I used the Windows XP recovery disk for my desk top computer on my Toshiba Satellite 1005-s157. I do not have the recovery disk that came with the system. How do I correct this? Can not get online plus no...
go to start/all programs/accessories/systems tools / system restore and restore to an earlier date.........go back 2 months at least (when your laptop was working fine) ....the system will shut down & reboot up and prompt you with are sure this okay to do click ok.........
Jul 24, 2010 | Toshiba Satellite 1005-S157 Notebook
New portable Win7 won't make recovery disk
Okay....take a deep breath, we'll do this step by step.
1. Go to the following link: http://www.msi.com/index.php?func=driverfile&dno=9927&i=0
2. Select where you want to download the file from. It's best to pick the one that reflects your location.
3. Once the file has been downloaded, extract the folder to someplace you can find it again, e.g. Desktop or MyDocuments or something like that.
4. Run the file called "setup.exe" (without quotes)
5. Follow the directions of the installer
6. Taadaa! All done, you can relax again.
Good luck and don't hesitate to message me if you have any questions/need help.
Dec 26, 2009 | Computers & Internet
Missing recovery disk for Composer 5100
The recovery disk is usually stored as a separate partition on the hard disk itself (Mostly in cases of laptop disks), so when ever you purchase laptops with pre-installed Operating System, The very first thing you do is create a CD/DVD recovery disk ie burn the recovery partition on the CD/DVD.
so that you can use the same DVD in case the OS crashes.
In your case as your hard disk was crashed and replaced ask the people from where you purchased the laptop/pc to restore it to the new hard disk, or purchase the Operating System.
hope this clears the doubt
regards
Jun 22, 2009 | Computers & Internet
Recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Computers & Internet Logo
727 people viewed this question
David Payne
David Payne
