Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana Fridge ASD2522WRW03 - 6 months old - high-pitched whine while running - any way to fix the noise?
SOURCE: Whining noise from freezer
The problem is that the ice maker leaks ice often, and it collects around the fan, making the fan inoperable. This causes the whine noise. The only solution is to chip the ice away in the back by the fan, which requires emptying the freezer. This is the worst refrigerator we have ever owned.
Posted on Feb 04, 2007
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
Posted on Apr 22, 2008
SOURCE: center post on 11 year old side by side amana is hot
After checking all of that..
Try unplugging it for a couple of minutes then plug it back in. I found on my 27ft Amana side by side that the defrost control is controlled by a microcontroller based module near the bottom of the fridge. It was out in la-la land and in my case, was not defrosting the freezer coils. Cycling the power reset it and all was well.
Worth a shot. Good luck.
Posted on Jan 22, 2009
stephanos18
  • 144 Answers
SOURCE: My Amana fridge (model ARSE67RBB) compressor has
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Posted on Oct 30, 2009
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
Whine from 2005 corolla automatic transmission
Have the tranny serviced with fluid change and filter, if noise it still there it is the torque converter . Have the dealer fix it ,and have it on paper with dealer invoice when it is done. Do all this before warranty expires. IT IS NOT USUAL for any car, Toyota included, to have tranny whine!!!!!
Jan 23, 2010 | 2003 Toyota Sienna
Center post on 11 year old side by side amana is hot
check the coils underneath the unit to be sure they are clean if they are clean then check the condenser fan motor behind the cardboard cover on the back of the refrig. the motor could be bad or has an obstructuction. good luck peyton
Jan 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
Samsung SlimFit 30" high pitch whining noise
I have had the same high pitch tone problem for several months after about 20 minutes of use. It is so bad it's rendered the TV almost unwatchable. I contacted a repair place from Samsung's website. I was told that is likely the flyback transformer. I don't know what it is, but it sounds cool like a flux capacitator. I was told it would be about $100 to fix. However, I have had very little luck getting the repair shop to order the part and do the work.
Sep 04, 2008 | Samsung TXR3079 TV
GE FRIG Model GSL25JFPJBS
my ge fridge has a hi pitch sound.
I hate it
Aug 14, 2008 | GE Refrigerators
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Sep 05, 2007 | Amana ASD2326HE Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
94 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
