Question about Polaroid FLM-323B Television
No signal All functions work with tv: dvd, receiver, and over the air trans. However, when you initially turn on the TV, it will crackle. The POLAROID logo comes up and then goes to blue and says no signal for the HDTV. Ideas??
  • Anonymous Jun 17, 2008
    When I turn on the television, the Polaroid name comes up and then the screen goes blue and no signal appears in the upper right hand corner. Ir also has a whine to it and you have to mute the sound until the picture comes on which is at least 15 minutes or more. It will start flashing and crackling and finally a picture appears but it still has the whine.
  • treehousepsa Sep 22, 2008
    no signal shows up on the screen and loud whining then the tv starts blinking when the channel finally comes in.
  • 3 Answers
. I changed from my component video inputs to the ones on the side of the TV and that works. Seems like the high quality video receiver, i.e. the control box, is the problem, per other complaint sites.
Warranty is only for 12 months, otherwise it is an expensive fix.
Posted on Jun 08, 2008
  • 3 Answers
Mine use to do that; i'm hooked into directv. when it happend, I made sure tv mode was on antenna and the tv was on channel 03. solved the problem.
Posted on Dec 26, 2008
I have a Polaroid 26"
It is a bad tuner, the tuner needs changed or the tuner module and that will take care of your problem.
Dec 22, 2010 | Polaroid FLM-2634B 26 in. LCD Television
Video problem in FLM-1911
will a dvd player work in it direct with coumpount cables or yellow cable on dvd in or video 1 select new input on remote ?
Jan 19, 2008 | Polaroid FLM-1911 19 in. LCD Television
I have a 32" flat panel. Am only receiving one local TV station channel at this time. All other channels show "No Signal". We hooked another TV to the cable and it works fine. What could the problem...
The tv is good,just some LCD tvs some models require a very strong broadcasting signal to get a picture.U getting a free DTV air broadcasting signal wright?Tries getting a roof antena or a digital design antena.Tries this tv out again,will get all the DTV free air broadcasting signal.Should not get anymore "No Signal" result.
Oct 13, 2010 | Polaroid FLM-3201 Television
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
source from
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I have a lcd 37" polaroid tv / dvd combo I use to have it hooked up to Direct TV and now wanted to just get the free channels with an antenna. Eveytime I scan for channels it doesn't find any. Do u think...
go into the set up menu and set the signal input to AIR, the rescan for channels. Directv should have been going into a sat box then into a different input than the Ant jack so make sure your on the right input
Jul 16, 2009 | Polaroid Televison & Video
Does the model Polaroid TTM-2401 TV have a digital tuner?
Your TV will need a HD converter because it doesn't have a digital tuner but only if you are receiving over the air signals. If you have a cable box or satellite receiver, then you do not need the converter HD box.
Click here for more info on the TV specs.
Jan 08, 2009 | Polaroid TTM-2401 TV
Polaroid TLA-01511C
Tried to use my TV as a computer monitor. When tries to boot up, will go to "No Signal". All hooked up correct. Is ther something I need to do tobe able to use the monitor with my computer. I have a Dell Desk Top Computer.
Jun 16, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Tv making a loud crackling
The set should be under warranty, call the company or go on line and get a servicer out asap. good Luck
Mar 19, 2007 | Polaroid FLM-3232 Television
Polaroid FLM-323B Television Logo
127 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
