Question about HP Pavilion DV2620US Notebook
I have a hP pavillion dv2620us. I get an intermittent black screen whenever I use the laptop. During normal use, the laptop screen just goes dark/black. There is still power to the laptop and you can sort of see the screen if you look closely or look from a different angle. I've researched the problem and can pin point what the exact problem is. However, something that has worked for me is powering it down, putting it in the refrigerator for about a minute then restarting the laptop. This sort of indicates to me that i have a heating issue with the laptop. I've returned the laptop to factory defaults because I thought it was a virus problem but that didn't seem to solve the problem
  • 2,567 Answers
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter board. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Sep 30, 2010
  • yshobowa Sep 30, 2010
    I'll try this solution when I get home from work tonight.
My HP Pavillion G6 laptop screen goes black if not tilted in two certain positions
Sounds like the cable feeding the inverter is either faulty or has a bad connection. You will need to take the laptop to bits. See utube video.
http://www.youtube.com/watch?v=M7CEtfJtu_Y
Hope that helps.
Dec 29, 2013 | HP Pavilion Computers & Internet
Hp pavillion dv2 1005ee notebook PC goes black screen whenever i started it. What should i do? Also its keys not working while this problem.
h
to test if it is the lcd screen tis faulty or the inverter
plug in another monitor to the external monitor plug
when you turn on the laptop if the 2nd monitor displays the desktop your lcd needs to be replaced
if its also black your inverter needs to be repalced
aries
Oct 19, 2013 | Computers & Internet
My hp pavillion goes to black screen (no signal) intermittently and emit a beep tone
The video graphics card is one of the main problems with the HP line, it gets to hot causing the solder to break down. But I would test with a monitor on the video output to be sure.
Jun 26, 2012 | HP Computers & Internet
HP Pavillion Laptop 1/3 Bottom Screen intermittently inaccessible
Sub out the ram memory one at a time and to see if this will make the difference.
Apr 22, 2012 | HP Computers & Internet
My HP Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
That means your backlight is going out. The fact that it's happening intermittently like that suggests that you have a faulty screen inverter (a small circuit behind the screen that converts DC power to AC, in order to light the florescent backlight).
I suggest replacing it. Here are some on abay for pretty cheap:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A2608&_nkw=Pavilion+dv4000+inverter&_ipg=&_sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Mar 24, 2010 | HP Pavilion dv4000 Notebook
Hp pavillion laptop screen goes black
its the common problem with graphic card, if its nvedia chipset graphic, there is only one temp solution, ask any hardware machanics to put a glue and heat the display ic, then it would work for a week, in that period buy the amc from hp service centre, after a week if there is a prob, company will have to replacd the motherboard
Feb 10, 2010 | HP Pavilion dv6000t Notebook
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavillion entertainment dv6000 - Power goes
it is problem your laptop ram is rough position or demage change it then your laptop is active
Jul 17, 2009 | Computers & Internet
Hp pavillion trying to boot from dos mode
This is a common HP laptop problem.
Please try these steps, if they dont work you will have to do a restore.
Please let me know how you make out.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372724&cc=us&lc=en&dlc=en&product=1137817&dlc=en&lang=en
Dec 08, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion DV2620US Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
