Question about Discovery Kids Discovery Ann B Dextrous Motor Developer
Where can I get a manual for my Ann B Dextrous Motor Developer?
Received a hand-me-down of the Discovery Ann B Dextrous Motor developer from a friend with no manual. I need to know how to find out how to use it and change the settings.
Posted on Jul 03, 2011
Controls / CONTROLLER FAN MOTOR
Yes its the developer motor. mite need to be replaced I would check the developer unit first, also mite replace the developer
Aug 28, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Code 2103
Developer motor MCY error
After developer motor MCY is
driven, the ready signal does
not turn to L within 5 s.
stabilized, the ready signal is
at the H level for 5 s continuously
Aug 08, 2014 | Kyocera Office Equipment & Supplies
What is error code c/6 400 on koycera km2020
Developer unit
MCY
1. Check that the developer waste lock has
been released and, if not, release the
lock (see page 1-2-15).
2. Check that the gears and spiral screw of
the developer unit are not damaged.
3. Confirm that the developer roller can
rotate.
4. If it won't rotate, replace the developer
unit (see page 1-5-57).
Developer motor
MCY
1. To check the motor operation, execute
DLP(MCY) by U030 (see page 1-3-34).
2. Check the drive gear can rotate or they
are not unusually loaded and, if
necessary, replace.
3. Confirm that the wiring connector is
firmly connected and, if necessary,
connect the connector all the way in.
Developer motor MCY and Motor
control PWB (YC7)
Motor control PWB (YC3) and Engine
PWB (YC9)
4. If the wiring is disconnected, shorted or
grounded, replace the wiring.
5. Replace the Developer motor MCY.
Motor control PWB Replace the Motor control PWB
Engine PWB. 1. Check the engine software and upgrade
to the latest, if necessary.
2. Replace the engine PWB (see page 1-5-
80).
Aug 07, 2014 | Kyocera Office Equipment & Supplies
Motor does not run properly
What motor are you talking about the fuser motor, paper draw motor, the finisher motor, the transfer motor, the drum motor, the developer motor, corona wire transfer cleaning motor. I can go on.
Replacing developer and toner has nothing to do with the motor running,
Aug 06, 2014 | Sharp AR-5320 Black and White Copier
Error59.c0
Per my service manual for this printer, the 59.C0 error states:
The product has experienced a developer motor error.
Recommended action:
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. Turn on the power and wait for the product to initialize.
If the error persists, replace the developer motor.
If the error persists, replace the DC controller
Apr 08, 2014 | HP Laserjet CM2320nf All-In-One Color...
I have a Lexmark C510 which display a 910 service engine motor. Can you tell me what motor this is?
910—Developer motor service check
Step Questions / actions Yes No
1 Are there any unusual
noises heard around
developer motor or
developer drive assembly
before error posts?
Replace toner
cartridge
Does problem go away? Problem solved.
If not Replace
developer motor
and/or developer
drive assembly.
Partnr developer motor:
56P1627
Partnr Drive assy: 56P1628
Jul 15, 2009 | Lexmark C510 Laser Printer
Service Engine - Error Code indicates o2 sensor issue
Go to the dealer and order an owner's manual. It usually takes a special socket and strong dextrous arms to replace an O2 sensor. Let the pro do it.
Jun 16, 2009 | 2004 Mitsubishi Outlander
How do i use this?
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Apr 03, 2009 | Sharp Office Equipment & Supplies
Neosca63
Subject:
C0030 code is displayed and will not reset. The C0030 is referenced to the developer drive motor for the 4 developer units. developr motor is binding
hope that helps
Jul 04, 2008 | Konica Minolta DiALTA CF910 Copier
Error code on kyocera fs-3800 printer
E1: xxxxxxxx = Main motor error
Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
below is stuff from service manual and ....my comments
Suggested causes
The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
• Connector insertion error........check developer plug is secure (left top near toner cart little plug)
• Defective gate array U204 on the engine
board (KP-864). .......replace board
• Defective harness between engine board and
engine relay board (KP-760). .........secure replace cable
• Defective harness between engine relay board
(KP-760) and main motor.
Nov 26, 2007 | Kyocera Mita FS 3800 Laser Printer
Discovery Kids Discovery Ann B Dextrous Motor Developer Logo
582 people viewed this question
Top Discovery Kids Toys Experts
Tre Elkins
Stan Ford
Are you a Discovery Kids Toy Expert? Answer questions, earn points and help others
