TV has picture but no sound (cathode ray TV) - Televison & Video
  • bnc_simpson Sep 30, 2010
    Thank you very much. Before I contacted fixya.com I had cycled as a first step but probably for no more than a minute or two. I also had forgotten to try a DVD.
    I ran a DVD and the sound was fine. TV set not at fault. I powered down and ran an errand to allow adequate time. Fired everything back up and the sound works.
    Other TV sets in the house, directly connected to cable, never lost sound. The only TV that lost sound was the one connected to the "box." I now have a tiny bit of "snow" in the picture but the sound is restored.
    My conclusion: the set is fine, the problem is in the "box." I'll call the cable company.
    Your suggestions woke me up. Case closed. Well done.
    Cal.
    The suggestions were very helpful. Problem identified.
    President:
  • 2,777 Answers
Hmm, usually the problem is the other way around! And this is on all inputs with the TV? For example, with regular TV viewing and with DVD watching, it does not have any sound? And of course I have to ask the obvious question - you are sure it is not muted? If you mute then unmute does it appear to be trying to do it (displaying something on the screen for example)?
Have you tried simply unplugging the TV for a good 10 minutes from the power source, then replugging it in? If it continues to have no sound it could be a failed sound module inside the TV. I doubt both speakers in the TV failed at the same time, so this is really all that makes sense.
Thanks
Tim
Posted on Sep 30, 2010
I have a Mitsubishi HD 1080 model ws-48315 and at first I had no picture only sound but when I started to adjust the lamps focus and color brightness the picture stastarted to come in but it now blinks
It sounds to me that the cathode ray tubes or the high voltage splitter is going bad. There is no lamp in this TV. it uses the older CRT type display technology. Time for a new TV.
Jan 18, 2015 | Mitsubishi Televison & Video
Tip
Cathode emission check for colour picture tubes
<p>How to check the colour cathodes of a picture tube for emission<br /> <p> <br> <p>It is very easy to cehck the emission of the cathodes of a colour picture tube. Assuming all other circuit parts are working, including LOT [Line output Transformer] and video output section.<span> </SPAN>There is proper screen voltage; focus voltage and EHT [Extra High Tension]. Locate the three cathode points on the base card, usually marked as Gk, Bk and Rk.<span> </SPAN>Keep the brightness, contrast and colour control to zero position.<span> </SPAN>Take a wire of suitable length, say 50cms or so, tie its one end to TVs chasis [negative].<span> </SPAN>Take one resistor of value 100K 1W, tie its one end to the other end or the wire, thus one end of this resistor is now connected to negative chasis and the other end of it is free now.<span> </SPAN>Hold this resistor with with some electrically noncunductive material [using hand gloves will be better]; switch on the Tv, wait a minute or so to get it warm up.<span> </SPAN>Just make a touch at each cathode of the picture tube base card solderings.<span> </SPAN>Just one touch will give you a colour of the respecive cathode on the screen.<span> </SPAN>Never hold it for long time. This process can be used for checking cathode emission of any type of Cathode Ray Picture tubes. <br> <p>
on Apr 18, 2011 | Televison & Video
Tv comes on sound only. No picture
If this is the old style CRT TV then it sounds like the picture tube has gone, the Cathode Ray Tube is not an economical replacement.....unfortunately it will have to be disposed of and replaced!
Jan 04, 2015 | Televison & Video
I have a Sony KP-61XBR-300 rear projection tv---- Picture went out. Is this the light bulb and if so where is located. Can I get it out myself?
This is a projection TV: it uses cathode ray tubes instead of bulbs. If you have a black screen, but still have sound, then the problem is on one of the circuit boards. Very few parts are available for this model.
Dec 05, 2010 | Sony KP-61XBR300 61" Rear Projection...
My samsung le40r73bd tv has developed a fault the tv switches on and you get sound and picture then after approx 2 minutes screen goes blank and sound remains other times tv comes on with sound but no...
there is a problem on your inverter board and the cold cathode lamp.The inverter board is the supplying high voltage supply to the cold cathode lamp.This cold cathode lamp is the illuminating the screen in which the the picture will appear once cold cathode is lit.here is a link where you can buy the parts.. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
  2. http://s807.photobucket.com/home/budm/allalbums
:Good luck hope this helps you..
please rate my help
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Picture has blue shadow/trail? sony KP-53HS10
This sounds like a bad blue CRT (cathode ray tube) The repair on this is a major job. Beyond the tube replacement it would then require some convergence alignment and possibly some setup on the other related service adj. such as geometry. You may want to get an estimate from a reputable local repair company.
Jan 25, 2010 | Sony KP-53HS10 TV
No sound or picture on magnavox tv
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have no picture,but i have sound.I have light gray lines on the left side of the TV monator.
Jun 02, 2009 | JVC Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
