Question about EnGenius EAP-3660 802.11b/g Wireless Access Point
I have setup the Engenius EAP-3660 as a repeater and have the same problem as TOMA 2/28/10, no DNS connection. Prior to turning on the repeater I'm connected to the internet and both the IPv4 DHCP and IPv4 DNS servers connected to 192.168.1.1. After the repeater is on for a minute or so both the DHCP and DNS dissappear and my internet connection is lost. Is there a conflict with the IP address since the repeater is set to 192.168.1.1?
Macs R We
  • 481 Answers
SOURCE: engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
Posted on May 17, 2010
Macs R We
  • 481 Answers
SOURCE: I set up the Engenius EAP as a repeater and can
Signal is only one part of the complete connectivity problem. Your lack of connectivity is almost certainly due to some other component, such as your second laptop having an incompatible static IP address specified, or no DNS servers specified.
First, ensure your PC is configured for a dynamic IP address. Once you have acquired good signal and connected, check to see that you have received a dynamic IP address. If that works, open IE and type in the numeric IP address if your EPA repeater. If you get a response, the problem is not your wireless connection or local IP address. Now type in the IP address 74.125.19.103 . If you get a response, your problem is that you have no DNS servers specified.
Macs R We
  • 481 Answers
SOURCE: How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Posted on Jun 17, 2010
SOURCE: How to set up EnGenius EAP-3660
Get the manual from website
Posted on Jul 28, 2010
Macs R We
  • 481 Answers
SOURCE: Hi, I cannot setup my
You need to enable the DHCP server on the EOC-2611P. Then it will negotiate an IP address with your PC without you having to set one by hand.
Posted on Oct 27, 2010
WiFi disconnects
the problem with your AP , change it
Mar 14, 2014 | EnGenius EAP-3660 802.11b/g Wireless...
Can't log in Engenius EAP-3660 .after rest factory settings.why? can you help me pls
You don't seem to understand what an Access Point is.
an AP is used to extend your wireless range and will connect to your routericon1.png to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
a router is an AP that will allow you to connect to your ISP for internet connection. A router can be configured to work as an AP but a AP cannot function as a router.
Read the manual. When you reset the AP the IP of the AP device became 192.168.1.1
That means you need to set the IP address of your computer to 192.168.1.x where x is anything from 253-2 and the subnet mask to 255.255.255.0
Feb 19, 2014 | EnGenius Computers & Internet
Problem loging into the web page of EnGenius EAP-3660 Access Point
I thought the default IP was 192.168.0.1. That is where mine went when I pressed the reset button.
Jan 10, 2013 | EnGenius EAP-3660 802.11b/g Wireless...
Jul 28, 2010 | Computers & Internet
Engenius eap-3660 access points channels chashing.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
I set up the Engenius EAP as a repeater and can connect to it with my lpatop and Iphone. When I try to connect another laptop I have excelletnt connectivity reception, but Internet Explorer cannot display...
Feb 28, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
EnGenius EAP-3660 802.11b/g Wireless Access Point Logo
462 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
