Question about Brother SX-4000 Typewriter
Changing the ink and the correction tape. - Brother SX-4000 Typewriter
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around in there you will find a downloadable manual.
DickyO
Posted on Sep 30, 2010
Ink cartridges keep popping out when i close the printer door
The cartridges are not seating all the way - are you sure all the tape has been removed from the cartridge? Also, use a flashlight and look on the ink cartridge carriage - make sure there's no paper of tape sitting on it that would keep the ink catridges from seating properly. The ink cartridges should go in and you should feel them click into place.
Nov 16, 2013 | HP Officejet 5610 All-In-One InkJet...
Changing correction tape in model SL 105 I am attempting to put in a new correction tape in my Model SL 105. It appears to be moving, but I am getting no correction.
If the correction tape is moving and lifting there is a good possibility that the ribbon or correction tape are old and have changed composition or you have a non correctable ribbon.
DickyO
Sep 21, 2011 | Smith Corona Office Equipment & Supplies
Not printing blak
Open up All printers and faxes by right clicking the printer icon in the system tray.On the maintenence tab check your black ink.Check to se if the tape is stil on the carftridge. If it is remove it. Printer should print black ink once the tape is removed.If it is removed. Try changing your black ink for a new one. Also sometimes your ink may not be compatible. Make sure you use compatible ink
Jan 29, 2011 | HP Office Equipment & Supplies
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Go to brother.com, click on support you will find a manual there.
DickyO
Jun 25, 2010 | Brother EM-530 Typewriter
Black ink not printing
Dear Friend, Check & confirm the following will help you...
  • Check ink tank situates Properly
  • OR Install recommended Ink tanks in Perfect Order
  • OR Remove Tape[Confirm there is no Orange tape across the top of ink tank]] From the Ink tank
  • OR Replace Ink tank
  • OR Perform Deep Print Head Cleaning
  • OR The Print Head may Need Replacing
>i860_install_inks_animation Click here
Above picture is the Correct View.... If this helped you,Do rate ME...Thanks For Contacting FixYa....
Apr 22, 2010 | Canon i860 InkJet Photo Printer
i have the same problem. can't find a manual anywhere. someone please help
Mar 10, 2009 | Brother ML-100 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
Correction Tape
Is the ink cartridge correctable ( yellow or orange core) not nultistrike (blue core) ?
Aug 29, 2007 | Brother EM-530 Typewriter
Brother SX-4000 Typewriter Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
