Question about Briggs & Stratton Garden
My pressure washer starts fine, shoots water OK. After running for 5-10 minutes cleaning siding I shut off machine. I go to start it again within a minute or two and the thing feels like it's just about seized. If i wait until the motor is completely cool, it will pull start freely and start right up. I think something is wrong with the pump, not the engine.
  • gfdgary Sep 30, 2010
    Thank you PC_Tech50 - what link or what URL? No links posted. - gary
    Thanks for the link and your response. When I get home I'm going to try your solution of holding the trigger open before I go for an EZ-start valve. I like your comment on using the valve may present another area that can cause problems over time. Thanks!
    President:
  • Briggs & Str... Master
  • 1,388 Answers
Your pressure washer may not have an ez-start valve installed from the factory. Without the ezstart valve, you will need to hold the trigger on the wand open to release the pressure to easily start your engine. This link will show you what an ezstart valve looks like. Ez-start valve is really not needed if you do not mind the extra effort to release pressure. Just more parts to go bad. Money well spent would be a method to easily inject oil or stabilizer into your pump when in storage. The oil/spabilizer will displace the water from within the pump and lubricate the internal parts and prevent freeze damage. Good luck
Posted on Sep 30, 2010
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
Craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Jan 29, 2010 | Briggs & Stratton Pressure Washer...
I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 07, 2009 | Honda Pressure Washer PSI 3000
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
Whirlpool LSQ9500LQ0 stops runs only for about 2 minutes
Try this first..Same thing happened to me yesterday..
I pulled the washer away from the water source..unscrewed the water lines from the water intake (not the washer)..there is a screen in the both hot and cold ...my screens were filled with debris..after cleaning the screens the washer works just fine..try this easy fix before you start looking into things like the motor or a switch somewhere...
Dec 19, 2008 | Washing Machines
No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Oct 28, 2008 | Karcher 2500 PSI Pressure Washer
Electric Pressure Washer
try running the machine without the hose attached if the machine runs ok then it is probable the there is a blockage in the nozzle if the the machine still cuts out then the pressure switch will probably be stuck or faulty this switch will be inline with the on/off switch and the motor it can be checked using a multi meter after dissconecting the power.
Oct 14, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
234 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
