Question about Plumbing
I just moved into a new apartment and have never used a bidet before, hence i wanted to experiment. it is in korean and i was pushing buttons i wasn't sure of and then three lights started blinking. now i get no response from any of the buttons. one of those blinking is the power button, i know that much. i can't seem to turn it off or reset it even after unplugging. please help. thanks.
SOURCE: mitsubishi diamond series tv
I have a 2003 mitsubishi WS-55711. While watching TV the other day it just shut off. When I pressed the power button, the green light turned on for approximately 3 secs, then shuts off. I've attempted to simply unplug it for a period of time in hopes that it would possibly reset. However, the same thing happens. Is this a problem I can fix on my own or does a professional need to fix it? If I do have a pro fix it, what is the likelyhood that it will happen again? Should I just invest in a new TV? Thanks
Posted on Oct 05, 2008
  • 188 Answers
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Apr 01, 2009
SOURCE: dell x50v won't turn on
while pushing the power button , push reset button for couple of seconds. hope that helps as that is what worked with mine.
Posted on Jun 12, 2009
  • 8457 Answers
SOURCE: I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Posted on Aug 20, 2009
SOURCE: hitachi power light blinking
Does anyone know how to fix this very common Hitachi problem without paying a repair man? And if you did pay a repair man did they fix the problem, and how much was it? I absolutely LOVED this TV before this happened. :(
Posted on Aug 07, 2010
Improperly installed toilet which caused damage
You need to contact their corporate office to complain.
store experience,
lowe's corporate
Questions or comments related to your experience in a Lowe's store or questions regarding Lowe's Corporate.
Phone: 1-800-44LOWES (56937)
Fax: 1-866-925-6620
Email: WeCare@lowes.com
Contact Us
Jun 17, 2016 | American Standard Home
How to change language from Korean to English setting?
Swipe down from top to bottom on the start screen. This will display a screen with wifi, location,bluetooth, etc. At the top there is a symbol that looks like a gear. Press the gear button (settings). This opens a new window. On the top of this window their are 4 buttons. Press the second button(has a person next to a cell phone symbol). In the new window scroll down until you see a white tile with an 'A' in it. Press that. In the new window press the top button '?? '. Scroll down and find English.
Jun 02, 2016 | Samsung Cell Phones
Samsung remote BN59-01134B not working. Trying to disassemble as replacements I'm finding are only in Korean. No screws visible. Wary of prying open without knowing where to pry.
Most remotes or at least many snap together and some have screws as well. Pushing in on the sides will sometimes open them. If not usually a tiny screwdriver flat ended will usually get a part started and keep it moving along the edge until you can get a second one in the seam. When you get the Remote apart check the connections on the front LED. Resolder carefully not putting to much heat on it for too long. Then get a pencil with a good eraser on it and clean all the connections where the buttons strike the contacts on the circuit board. Then your remote should work and if it doesn't get a universal remote and use that after programming using manuals designed to do so.
Sep 16, 2014 | Televison & Video
Bosch innowave hmt 8625GB My Bosch start button no longer works . When you push it in, it just moves to the left or right ... Can anyone please advise .. Thx Adam It is about 10 years old , not sure...
There are no spares listed for the power button. You may want to see if it came loose as opposed to broke. That means take it apart. However, that unit is not made anymore.
Dec 02, 2013 | Microwave Ovens
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
There is a rubber washer between disposal and sink basket
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, and push in reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
Attachment ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
Overexposure
The top of your cam should have a square button with a positive and negative sign. (I have the S5200, so it shouldn't be that different.) Hold that button down while pushing the button for "Macro" (the one with the little flower. On your LCD the number in lower right hand corner (FStop or something) should decrease (or increase - if you push the right side of the button.) All the buttons have names, and I apologize for not just getting my manual. Just experiment........it won't hurt (of course, you may want to experiment on just a table or something......you know nothing serious until you get the hang of it.
ric
May 21, 2008 | Fuji FinePix S5000 Digital Camera
Calling 1 800 numbers
press the button on the side which u swap profiles with whilst ur call is connected this then unlocks the screen and shows u the keypad
Nov 05, 2007 | LG Prada KE850 Cellular Phone
English Version of TG Dream Combo M4100 Printer's Driver
give me more info of you printer full name version etc
Sep 19, 2007 | Computers & Internet
Plumbing Logo
42 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
